Author Topic: RNS 510 mic install  (Read 8536 times)
Offline coop
RNS 510 mic install
« on: August 02, 2010, 11:43:46 pm »
Hi Guys
Just fitted my RNS510 Ver C and all good so far, havent even coded it yet and all seems to work. I have noticed its got voice control im guessing I need to install a mic for it to work, can anyone advise what I need to buy and how to go about fitting? I also intend on adding bluetooth at some point I assume any mic I install will work with a phone as well as the voice control? Cheers
Offline mortygttdi
  • -Receive: 146
Re: RNS 510 mic install
« Reply #1 on: August 03, 2010, 06:12:34 am »
Offline coop
« Reply #2 on: August 03, 2010, 09:22:47 am »
Perfect Thanks, is there much fitting involved, where does the mic go, any guides on line. Cheers
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: August 03, 2010, 09:49:57 am »
The mic goes in the centre overhead console.
Stu...
Offline coop
« Reply #4 on: August 03, 2010, 11:32:31 am »
I'm not sure were you mean, I'm guessing it cant go in the same place as the satnav aerial as the aircon noise would interfere, so I would have guessed I need to run the cable along the drivers side front pillar, not sure though?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: August 03, 2010, 11:35:40 am »
It goes in this part -
Behind one of the 'perforated' sections.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: August 03, 2010, 11:38:31 am »
A couple of better pictures from Google Images -
Stu...
Offline coop
« Reply #7 on: August 03, 2010, 12:22:33 pm »
That looks tricky to fit, should the cabling between my rns 510 (07 GTi) to the overhead console already be in place or do I need to run a cable? if so is there a guide on how to do this, cheers for your help.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #8 on: August 03, 2010, 12:24:23 pm »
You'll need to run the cable yourself.  Along the roof, down the A Pillar and across to the RNS.
Stu...
cameluk
« Reply #9 on: August 03, 2010, 12:50:17 pm »
http://tos.pp.fi/koukku/voice_control_retrofit.pdf
Its pretty easy, a length of stiff wire or metal coat hanger is helpful to install the cable above the roof lining
Offline coop
« Reply #10 on: August 03, 2010, 01:20:29 pm »
Cool, thanks for the advice.
