Author Topic: Fitting Ariel Cable to Aftermarket Headunit  (Read 2908 times)
Offline Gordy
« on: August 05, 2010, 10:56:45 am »
Hi
I have just bought a Jetta which has an aftermarket headunit fitted however the radio did not work so I bought the correct cable for this - just like the one in this link:
http://cgi.ebay.co.uk/Volkswagen-Jetta-Amplified-Fakra-Aerial-Adaptor-PC5-137-/260485115419?cmd=ViewItem&pt=LH_DefaultDomain_3&hash=item3ca61f6e1b
However ofcourse the large connection goes straight in to the back on the headunit but what do the other 2 leads connect to - one should clearly be the ariel which is built in to the car as the reception is quite poor but does anyone know which cable it connects to?
Thanks in advance for any help!
Gordy
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: Fitting Ariel Cable to Aftermarket Headunit
« Reply #1 on: August 05, 2010, 11:20:56 am »
The other cable needs to go to a 12v switch live feed as the adapter is amplified  :happy2:
Offline Gordy
« Reply #2 on: August 05, 2010, 01:26:53 pm »
Perfect, thanks for the reply I will get it sorted tonight.
Offline Gordy
« Reply #3 on: August 06, 2010, 09:57:05 am »
I think I am being stupid but I was unable to identify the 12v live feed!
There are 3 "mute" cables which are free but dont think it will be one of those.
Also do both the extra cables on the Antenna Adaptor require to be connected - at the moment I only have the main cable connected to the back of the headunit but this is why the reception is so poor.
Thanks!
cameluk
« Reply #4 on: August 06, 2010, 01:31:26 pm »
You can find a switched live either at the cigarette lighter, on the back of the climate controls or in the fuse box
Offline Gordy
« Reply #5 on: August 06, 2010, 02:45:24 pm »
Thanks so the black cable with the blue plastic clip goes to that?
Wish it just came with the standard headunit  :grin:
cameluk
« Reply #6 on: August 06, 2010, 05:17:54 pm »
Black cable with the blue connector goes to the aerial lead thats in the car
Black lead with silver connector goes to the head unit
Blue wire needs to go to a switches ignition live feed which be found at the cigarette lighter, on the back of the climate controls or in the fuse box
