Author Topic: Plastic rattle/creaking noise on top of dash.  (Read 12222 times)
Offline CAPTAIN BRITAIN
« on: August 08, 2010, 10:36:58 am »
Has anyone else got a creaking and rattly noise from around the air vents on top of the dashboard,
Only really notice it whilst driving on rough bit of road (that's about 95% of roads in london)
Is there a fix for this, as it makes the golf sound cheap and flimsy, Not a good image if your carrying passengers  :grin:
Offline mackit
  • Surrey
Re: Plastic rattle/creaking noise on top of dash.
« Reply #1 on: August 08, 2010, 11:18:02 am »
I have the same problem.  I started a thread to ask about how to take the cover off.  Might be useful:
http://www.mk5golfgti.co.uk/forum/index.php/topic,16410.0.html
I was going to play around with some possible felt lining or some strategically placed tape.  So far....i've not been successful in taking the top cover off.  I'm scared i'm going to break something.  :scared:
VW Edition 30 DSG, 5 door, RNS-510
« Reply #2 on: August 08, 2010, 11:56:20 am »
There is a section behind the air vents that's known for causing a squeak. You'll need to have a little search for it though on the forums. Someone did a guide.
« Reply #3 on: August 08, 2010, 12:43:20 pm »
I hate dismantling stuff as i find i can never get bits to go back in the way they came out  :ashamed:
But i'll give it a try and have a poke around under the plastic vent thing.  :scared:
Offline SeanyK
  • -Given: 35
« Reply #4 on: August 08, 2010, 01:17:00 pm »
It's very easy to take that cover off, just use a credit card to pry it open, then unclip the sensor wire, and have a look, some cars have foam where 2 screws tighten in, that is supposed to stop the rattle.
What I did was buy some double sided tape circles, and put them around the base, almost 'jamming' the cover on when it was back in place.
Has worked a bit, not perfect, but until a better solution comes up it will do!
« Reply #5 on: August 08, 2010, 01:19:50 pm »
Sounds like a plan, I've got some small adhesive felt stickers  here so i might stick some of them under there
Offline DMcG
« Reply #6 on: August 09, 2010, 08:45:09 pm »
I bought an inerior trim removal tool set off the bay for less than £10 just to ensure I didnt scratch anything. It was simple enough to do. Just felt line everywhere plastic contacts!
Offline gtlee
« Reply #7 on: August 09, 2010, 08:48:56 pm »
CAPTAIN BRITAIN,
Mine does that too getting a bit peeved with the noise,would love to hear a fix for it!
Golf V 5DR DSG GT Sport,,Xenons,Full leather,18'Charlestons,Lux pack,storage pack,folding mirrors,front armrest, retrofited--mk5 gti  grilles,fog lamps grilles,GTi rear bumper,coloured coded sideskirts, VIM RNS-510 C,MK6 MFSW with paddles,GTi DSG gear lever,Cruise control,Highline.Rain sensor with window auto closure,TPMS.7P6 Bluetooth.
Mods to come: RVC, and.................
Offline keano
  • -Given: 79
« Reply #8 on: August 09, 2010, 08:58:51 pm »
U think the gti is bad?
I used to have a clio on coilovers. Was set harder than Ron Jerremy's c**k!  :grin:
If something didnt rattle itself loose or drop off, i'd be concerned  :confused:
Saint Steve
« Reply #9 on: August 09, 2010, 09:01:50 pm »
What you need is a small wedge of wood or form of plastic wedge, which if you remove the lower half of the top vent housing, there is a gap thats about 10mm. It has a stainless steel edge from memory where you fit the small wedge, and it then stops the top of the dash creaking.
Its not "just put sticky pads" under the grill on the top, its actually under that ,behind the radio that needs wedg' ing  :wink:
Offline Lyons
  • -Given: 18
« Reply #10 on: August 10, 2010, 01:32:10 pm »
On a warm day I have an awful squeak from teh left hand side of the glove box.  When I press hard against the glovebox door it stops. I just need a chance to strip it down and see if i can wedge in some cloth when rebuilding it.
Offline Tara
« Reply #11 on: August 10, 2010, 01:34:54 pm »
One of my vents started it a little bit so i just moved it around a bit and then it was fine :)
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #12 on: August 10, 2010, 03:35:32 pm »
........thats what i did with the dash top vent worked fine.Just need to do it every now & again. :grin:
Offline RENNTAG
  • Premium Performance Parts
« Reply #13 on: August 11, 2010, 08:06:52 am »
if its got the ipod kit for the stereo, the box the lead comes out of can rattle about if its not secured properly...
WILLZIE
« Reply #14 on: August 11, 2010, 12:05:18 pm »
I had this, like many others too!
Took it apart with patients as wasn't going to scratch anything, there was a good guide somewhere but I reseated it packed out with black duck tape, never came back again!
Watch out for the sterring coloum plastic housing too, mine wasn't tight but it sounded like a window was goina drop out!  :stupid:
