Author Topic: couple of fault code questions....  (Read 1713 times)
Offline heavyd
  • -Receive: 29
« on: August 18, 2010, 05:52:18 pm »
Basically, I took the centre air vent out, as I tried to fix the vent that wont close, but is broken so need a new one, but when I tried to fix it,I had to unplug the airbag light switch,  but afterwards I read that you end up with the airbags not working.
Secondly, I put some license plate LED bulbs in, then read that they throw up error codes( the ones I bought werent supposed to) but read the invoice after I fitted them, and it said they might..
I have no airbag warning lights on the dash, and no lights to suggest the bulbs are throwing faults, so does that mean I havent any faults? I only have a hex usb lead so cant check with VCDS
Thanks in advance for any advice or help....
Offline G4V VW
Re: couple of fault code questions....
« Reply #1 on: August 18, 2010, 06:02:47 pm »
Both faults would show up if they were active, the airbag light will only come on if you turned the ignition on whilst the switch was upluged!!  :happy2:
If no lights are on all is fine.
« Last Edit: August 18, 2010, 06:04:23 pm by G4V VW »
Offline heavyd
  • -Receive: 29
« Reply #2 on: August 18, 2010, 06:08:07 pm »
thanks :grin:
thought as much, but just wanted to double check, gotta get myself a vagcom lead when I get some spare pennies :wink:
