Author Topic: Tyre Pressure Warning  (Read 8328 times)
Offline ILoveTuna
« on: August 18, 2010, 06:52:14 pm »
Hi Guys hope someone can help.
On the way home tonight and tyre pressure warning light came on, so pulled over at the next garage and checked the pressures. One of the tyres was down to 30 psi so not flat by any means but got them all back to 2.4 bar anyways.
The issues is the warning light wont go off when i press the set button by the gearstick???  :sad1: :sad1:
Is there some kind of time delay or anything or is there a problem somewhere?
Thanks,
Offline Poppa Dom
Re: Tyre Pressure Warning
« Reply #1 on: August 18, 2010, 06:55:15 pm »
Hold the button in until it beeps to reset it  :happy2:
Offline jmspear
« Reply #2 on: August 18, 2010, 06:55:16 pm »
Have you followed the instructions re resetting in the manual? IIRC you turn off ignition, press button, turn on ignition, (can't remember if beep?) but you hold for a period ~ 10s then release, drive off and then the light goes out - simples. Anyway correct procedure in the manual.
Offline ILoveTuna
« Reply #3 on: August 18, 2010, 06:56:54 pm »
Cheers guys looking through the manual now just though it would be a simple button press!!  :signLOL:
Offline ILoveTuna
« Reply #4 on: August 18, 2010, 07:12:36 pm »
Thats done the trick should have know it was me being a dumbass it normally is!!  :signLOL: :signLOL: :signLOL:
Cheers...
Offline Poppa Dom
« Reply #5 on: August 18, 2010, 07:13:00 pm »
Glad you are sorted  :happy2:
Offline Ands GTi
« Reply #6 on: August 18, 2010, 08:13:57 pm »
Yeah what he said  :happy2:
MK5 (06) GTI; Previous: (57) Audi A3 TDI & (05) Seat Leon Cupra R 225 & (51) Seat Ibiza Cupra 1.8 20VT
Offline 182_blue
  • -Receive: 54
« Reply #7 on: August 18, 2010, 08:26:00 pm »
Just so you know mine went of on the edition 30 when one of the wheel weights came off, could be worth a check too
Offline ILoveTuna
« Reply #8 on: August 18, 2010, 08:46:44 pm »
Yeah will check that in the morning, although one of the tyres was down a bit so that is probably it. Not sure how sensitively it monitors the pressure?
