Author Topic: Need nelp with the fitting of a MEDIA-In Adaptor - SORTED!  (Read 6378 times)
Offline Sparky Craig
  • Looking To Sell my R32 :(
    • My R32 Page
« on: August 27, 2010, 07:34:21 pm »
Hi All,
Well Mr ebay has dropped another item off to me today and I`ve already got problems with it  :grin:
I`ve purchased a MEDIA-IN unit that takes place of my 6 Disc CD Charger under the arm rest.
Now I didn`t buy it with the a loom as it was cheap enough and I thought that on the off chance good old VW wouldn`t change the plug to connect these units .... WRONG....  :smiley:
So I`m looking for someone with a WORKING ETKA to try and find me some numbers of the plugs for the following pictures, so I can make a lead up to allow me to plug the cars loom into the new shaped connector...
Thanks in Advance for any help ...  :love:
This shows the units side by side...  Notice the different socket type.... (Same number of pins though!)
« Last Edit: September 02, 2010, 05:10:35 pm by Sparky Craig »
MPS
Re: Need nelp with the fitting of a MEDIA-In Adaptor
« Reply #1 on: August 27, 2010, 08:03:16 pm »
I've bought exactly the same thing as you and have exactly the same problem  :grin:
I think you need this wiring harness
http://www.kufatec.de/shop/product_info.php/info/p1113_c26_MEDIA-IN-MDI-Interface---Harness---VW-Golf-5.html
and change your CAN-Bus gateway otherwise you'll get a flat battery!
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #2 on: August 27, 2010, 08:53:32 pm »
Craig
You can no doubt make up the loom yourself, but obviously you'll need the pin assignments (I may be able to help) and the loom for the CD changer wouldn't be any good IMHO unless you moved things around on the Headunit end.
I'll have a look later mate.
Stu...
    • My R32 Page
« Reply #3 on: August 27, 2010, 09:06:23 pm »
Trust you Stu to come to my help again  :signLOL:
Cheers Dewd...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: August 27, 2010, 10:45:30 pm »
From what I can make out you need the following -
Quadlock Pin 9 > CAN Hi Orange/Violet to Pin 8 on the MDI
Quadlock Pin 10 > CAN Lo Orange/Brown to Pin 2 on the MDI
Quadlock Pin 12 > Ground Brown to Pin 1 on the MDI
Quadlock Pin 15 >Live Red/Yellow to Pin 7 on the MDI Can be used in lieu of Pin 4 on the Blue Connector
Quadlock Blue Connector Pin 1 (Aux In Left) > Green to Pin 10 on the MDI
Quadlock Blue Connector Pin 2 (Aux In GND) > Grey to Pin 4 on the MDI
Quadlock Blue Connector Pin 4 (CD Changer 12v Terminal 30) >  Red/White to Pin 7 on the MDI
Quadlock Blue Connector Pin 7 (Aux In Right) > Yellow to Pin 9 on the MDI
If you have Aux in already then you may find the three (1,2 &7) above are populated.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: August 27, 2010, 11:02:07 pm »
The Blue Plug is 3B7 035 447 B.
The Black Plug for the MDI is 8E0 972 112.
I think the repair wires for both of these are 000 979 009 E
Stu...
    • My R32 Page
« Reply #6 on: August 28, 2010, 07:53:10 pm »
Thanks again Stu,
I`ll order the parts and make a loom up and see if I can get it to work right  :drinking:
If I do ... I`ll let others know.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: August 28, 2010, 10:31:39 pm »
Good luck mate.   :happy2:
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #8 on: August 28, 2010, 10:48:20 pm »
By the time you have finished it would be far easier maybe not cheaper but easier to buy the loom, I got mine from ebay for about £25
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: August 28, 2010, 10:49:37 pm »
000 979 987 is 10m of the CAN cable 0.35mm CSA
000 979 980 is 10m of Yellow repair wire 0.35mm CSA
000 979 950 is the webbing for making the loom
Stu...
MPS
« Reply #10 on: August 29, 2010, 02:13:09 pm »
Darren
May I ask for the link? Also is there an alternative solution to upgrading the CAN gateway to resolve the battery drain issue as it seems to me a bit like using a sledgehammer to crack a walnut, and very expensive as well! I know with aftermarket headunits it is just usually a case of swapping pin positions around. Any help would be greatfully appreciated!
    • My R32 Page
« Reply #11 on: September 02, 2010, 05:10:09 pm »
Update -
Made a loom up today and all working great :)  :P
total cost of £22.04 from the stealers though for the bits  :ashamed:
I managed to use the existing CD changer cable and just made some changes at the head unit side and then made a old plug / socket to new type plug / socket with some repair wires and the new plug / sockets :)
I`ve got a VERY ruff picture taken when I had it half in half out which I`ll post if people want to see it  :rolleye:
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Need nelp with the fitting of a MEDIA-In Adaptor - SORTED!
« Reply #12 on: September 02, 2010, 05:23:46 pm »
Were the connections I posted above correct Craig??
Stu...
    • My R32 Page
« Reply #13 on: September 02, 2010, 05:30:41 pm »
All the rest was correct but after a little checking on other website`s I found a slight difference noted below...
You Had
I`ve got
Quadlock Blue Connector Pin 1 (Aux In Left) > Green to Pin 9 on the MDI
Quadlock Blue Connector Pin 2 (Aux In GND) > Grey to Pin 10 on the MDI
Quadlock Blue Connector Pin 7 (Aux In Right) > Yellow to Pin 4 on the MDI
Offline pazz
« Reply #14 on: September 02, 2010, 09:25:29 pm »
So all that time and effort and you saved nearly £3.
As Morty says, not worth the hassle. Save building looms for RVC's and other jobs!
