Author Topic: rich83 - Edition 30..... Breaking  (Read 779602 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=reevsofmkatnp957vj1dbsophp&/topic,19740.0.html
Re: rich83 - Edition 30 Rear Brakes
« Reply #2400 on: May 20, 2016, 08:06:27 pm »
Oddly... the fluid in the reservoir was filthy (as per the picture), but the stuff coming out of the calipers was fairly clean, just slightly darker than fresh OEM and a bit cloudy, looked a bit like olive oil.
I think it was changed 2 years ago when I had the brembos fitted. I did cook the fluid last year though.
I pulled 250ml out of each side of each brembo ( so 500ml per caliper) and about 300ml out of each rear. Probably far to much but at least I know its all fresh now.
« Last Edit: May 20, 2016, 08:08:43 pm by rich83 »
Offline th3_f15t
  • -Receive: 183
« Reply #2401 on: May 20, 2016, 09:24:40 pm »
I'm sure I've read somewhere that it's about 200ml per calipers on stock calipers so that's actually about right for bleeding. I pulled about the same amount through when I did mine, wanted to make sure I had absolutely no left over old fluid.
Offline doylebros
« Reply #2402 on: May 20, 2016, 09:26:52 pm »
200 ml fronts
400 ml rears
Is the quoted values in the VW blurb
« Reply #2403 on: May 20, 2016, 09:31:18 pm »
Cool. Looks like I did about right then. I plan to change the rear calipers soon anyway so might end up having to re-bleed them anyway.
The rear bleed screws are a complete twat to get too. Why make them so awkward?
Offline doylebros
« Reply #2404 on: May 20, 2016, 09:35:11 pm »
If your is a manual did you do the clutch - 100ml?
Offline th3_f15t
  • -Receive: 183
« Reply #2405 on: May 20, 2016, 09:39:13 pm »
Good shout about the clutch! Also, do you still bleed the MC on these cars like older ones?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=reevsofmkatnp957vj1dbsophp&/topic,90967.msg917089.html#msg917089
« Reply #2406 on: May 20, 2016, 09:42:52 pm »
That fluid is very dark for a vehicle which gets such TLC Rich
:ashamed: Ive seen worse.. but this was the beater.
05 | Tornado Red | DSG
« Reply #2407 on: May 20, 2016, 09:43:56 pm »
DSG.
Not sure about bleeding the MC. Not heard of that before.
Offline doylebros
« Reply #2408 on: May 20, 2016, 09:46:17 pm »
DSG.
Never bother bleeding MC unless it's a replacement.
Offline doylebros
« Reply #2409 on: May 20, 2016, 09:52:25 pm »
Ah but the beater is minus TLC Dazza so that colour is perfect for the neglected chart!
Offline th3_f15t
  • -Receive: 183
« Reply #2410 on: May 20, 2016, 09:59:55 pm »
Least it had actual brake fluid I suppose...
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #2411 on: May 20, 2016, 10:40:41 pm »
She just keeps going, passed the mot today :). The judder is coming back though :(
« Reply #2412 on: July 17, 2016, 11:40:53 am »
Booked my car in for some paint in august.
I noticed that one of my wings is f*cked... the paint has completely popped off.
So its in for both wings respraying and rolling and a dent in the rear quarter sorted out where some kind **** threw a stone at my car. Also a full machine polish to get it looking a little younger than its 9 years.
In other news.... very very quickly approaching 100,000 miles
Offline th3_f15t
  • -Receive: 183
« Reply #2413 on: July 17, 2016, 01:42:59 pm »
Not sure if modern VW engines are the same, but I'm pretty sure the official line from VW regarding the old 1.8 8v and 16v engines was that the bottom end wasn't fully worn in till about 80,000 miles, but if it does apply then it means your engine has only just begun using it's full potential. :happy2:
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #2414 on: July 17, 2016, 03:16:27 pm »
I admire your positive outlook.
Think I'll have replaced the lot by 100k at this rate, bar the head and block.
