Author Topic: VW Golf Mk5 door handle lighting installation instructions.  (Read 36232 times)
Offline remix
Re: VW Golf Mk5 door handle lighting installation instructions.
« Reply #15 on: December 30, 2010, 01:03:45 am »
i see...
But i want put the back ilumination working like the front doors..  :sad1:
The way you make.. wen you turn off all lights, the handle ilumination go off too..
Thanks..
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #16 on: December 30, 2010, 09:32:46 am »
Then you need to change your door controllers, to newer ones
Cluster and Key coding
Location Great Yarmouth
Offline cmdrfire
    • Commander Fire - my blog
« Reply #17 on: January 14, 2011, 11:49:36 pm »
Part # for the door handle inserts with the LEDs fitted?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #18 on: January 15, 2011, 06:48:10 am »
There is no part number for the Golf/Jetta the ones you see, they have been made
Offline mortygttdi
  • -Receive: 146
« Reply #19 on: January 15, 2011, 06:51:22 am »
It has to be made mate,  they don't come like that.  The part that lights up is from a Touareg and cost about £2.50 you need to then measure the optic with the handle and dremel out the aparture so the optic can fit in then it needs to be hot glued in.
http://forums.vwvortex.com/showthread.php?3671139
Darren
Offline mortygttdi
  • -Receive: 146
« Reply #20 on: January 15, 2011, 06:52:05 am »
Wow some else is up other than me, how you doing Ed :happy2:
Darren
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #21 on: January 15, 2011, 09:55:13 am »
Hi Darren
Yes, had to get up early as my car was booked in for its MOT
it passed, without any issues :star:
« Last Edit: January 15, 2011, 10:01:23 am by Eddie-NL »
Offline siLc
« Reply #22 on: March 23, 2014, 03:19:29 pm »
What rotary tool bit was used to cut the door handle case plastic? I'm in the process of doing my front doors next week and need a little guidance.
Offline Timepillow
« Reply #23 on: March 23, 2014, 05:16:12 pm »
Wow! I want this in my car now! looks amazing and OEM so thats a plus  :wink:
Offline siLc
« Reply #24 on: June 03, 2014, 08:32:30 pm »
My front doors are done and wired up like from the factory. I bought rear door handles off a breakers and modified them. Now I need to sort out the rear controllers. I too have the lowly 1K0 959 703/704 C (GEN1) controllers, which need to be swapped out for newer ones. As I've concluded, 1K0 959 703/704 F (GEN2) should work for me because it is used in the 2005 Passat B6, which at the very least should have door exit lights from the factory. Any ideas?
Offline siLc
« Reply #25 on: December 09, 2014, 07:49:51 pm »
Since nobody has bothered to answer, I'll try to add some useful information myself for those with pre-MY 2007 Mk5-s.
I bought the aforementioned rear door modules off of a 2005 Golf Plus and while their VCDS measuring blocks show no sign of exit warning lights, there is a measuring block for door handle illumination. When the module is coded for handle illumination, the block's value changes to 100% when the handle illumination is called for.
I have opened up one of the modules and observed the module's printed circuit board against a light and after a process of elimination, I've come to the conclusion of either pins 5 or 8 of the 18pin connector are the +12v for door handle illumination.
Who is willing to give it a shot?  :grin:
ecarruda
« Reply #26 on: March 17, 2017, 02:15:06 pm »
i see...
Thanks..
Did you found any solution?
Offline Sebas_theFish
« Reply #27 on: July 24, 2019, 12:02:39 pm »
What pins do I use in the rear if 14 and 4 are already used for the door warning lights?
