Author Topic: fitting recaro pole positions into my mk5  (Read 15032 times)
Offline chrishalfpenny
« on: October 28, 2010, 05:29:08 pm »
On monday i have a day off and i will be fitting my recaros, what i want to know is is it as easy as taking the old seats out and bolting in the new sub frames?
Offline QD MBE
  • -Receive: 102
Re: fitting recaro pole positions into my mk5
« Reply #1 on: October 28, 2010, 05:44:51 pm »
You will need to code the airbags, I am assuming the Pole Positions don't have airbags?
« Reply #2 on: October 28, 2010, 06:15:16 pm »
No they haven't got airbags
Offline tony_danza
  • -Receive: 112
« Reply #3 on: October 28, 2010, 06:16:45 pm »
I think you can buy airbag resisters that fool the car into thinking they're there. Easier to code them out though.
Otherwise, bolts off, seat out, subframes in, seat in - job done!
Oh, and then pics!
Sideways yo!
Offline QD MBE
  • -Receive: 102
« Reply #4 on: October 28, 2010, 06:17:47 pm »
Then you will need to disable the seat side-airbags, or you will get a airbag light on the dash.
« Reply #5 on: October 28, 2010, 06:52:02 pm »
Cheers guys dash lights don't bother me so much just don't won't airbag to the face :signLOL:
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 96
« Reply #6 on: October 28, 2010, 08:10:03 pm »
Airbag dash lights are an MoT failure, not to mention failing to comply with Type Approval.  Both will mean you'll invalidate your insurance.
Legal spiel clarified, now tecchy info - if the airbag light is on, then ALL SRS components are disabled - so ALL airbags wont work, and your seatbelt pre-tensioners wont work either.
So for the sake of hooking up VCDS, it's well worth doing the job correctly.  :wink: :smiley:
Then you can fully enjoy your lush seats! :driver: :driver: :driver: :driver:
« Reply #7 on: October 28, 2010, 10:40:43 pm »
Useful info right there!
« Reply #8 on: October 28, 2010, 10:51:53 pm »
....You'll only fail your MOT if your airbag light stays on. Even with VCDS you won't be able to totally disable the airbag light: It'll come on as part of the initial systems check (probably the wrong term) and then disappear like the others normally do when all is well. If the airbag light stays on, then it means you've got a problem with those airbags present and hence a MOT fail.
The system behaves according to the seating option which the VW factory fitted to your chassis number. No VW dealer is willing to change that because of potential legal implications.
This was my experience in swapping to Recaro's.
  • -Given: 88
  • -Receive: 96
« Reply #9 on: October 29, 2010, 09:03:23 am »
OK smarty pants - you know that's what I meant!  :P
But yes, you are correct - many lights will come on when you turn on the ignition - as part of the check, and then go out very shortly after.  And you can't remove the bulb either - the MoT will test that the airbag light specifically illuminates, and then goes off (and the same for the ABS light too).
Not really correct.  Yes, the programming of all the control modules should be done according to what was factory fitted - however, VW garages (and all VAG garages) have a specific ability to link the car directly back to VW Germany to alter the base settings (technically known as 'PR' codes) when the car has been altered with genuine VW parts.  Some specific examples are retro-fitment of genuine towbars, and retro-fitment of Audi ceramic brake systems.  Retro-fitting of genuine Recaro seats should follow the same procedure.
The real problem is that many stealer 'technicians' just cant think outside the box.  On my own GTI, I had repeated problems with the airbag light, from their incompetence to correctly carry out a TSB on underseat wiring.  I specifically repeatedly asked them to temporarily disable the individual airbag (from when I poped into the stealer to show them the prob - to when the car was actually booked in to do the job), so that the airbag light would go out, and I would be able to have the remainder of the airbags and pre-tensioners fully functioning - and they refused.  They also REFUSED to clear the fault codes - meaning that the car had NO SRS functions for upto two weeks whilst they waited to book in.  :fighting:  This resulted in a formal complaint to VW UK.
« Reply #10 on: October 29, 2010, 11:11:49 am »
....Makes a change for me to be the Smarty Pants rather than you!  :laugh:  :happy2:
I didn't know about the VW Germany link back, so very useful info. Thanks, Sean  :drinking:
« Last Edit: October 29, 2010, 11:14:10 am by RedRobin »
Offline Garth
    • My Build thread
« Reply #11 on: October 29, 2010, 11:45:26 am »
Not completely true.
If a warning light is not visible, it will pass. On a previous car I had an ABS warning light AND airbag warning light come on the day before MOT due to me messing around with electrics. I didn't have time to fix them before the MOT so on the advise of my mechanic, I stuck black tape over the lights. It passed the MOT because no warning lights were visible and the MOT tester is not allowed to remove trim. Black tape is considered trim so he can't remove it  :P
  • -Given: 88
  • -Receive: 96
« Reply #12 on: October 29, 2010, 11:59:18 am »
But the Police can remove it - and then you'd be done under Construction and Use Regs - with a penalty much worse than no MoT.
« Reply #13 on: November 04, 2010, 01:59:32 pm »
So seats are all fitted but I feel they are too high, I like to be sat as low as possible but these recurs can't go any lower. I remember Johnny c had the same problem I'm sure, can anyone remember how it was solved? Please don't make me read through that mammoth build thread :)
« Reply #14 on: November 04, 2010, 02:21:32 pm »
Can't really remember but I know he sold his first ones to Robin.
http://www.mk5golfgti.co.uk/forum/index.php/topic,3742.msg57238.html#msg57238
