Author Topic: stock mode after battery disconnect query  (Read 3249 times)
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« on: November 02, 2010, 10:02:28 am »
as you all know I fitted my THS mounts at the weekend, so battery has been off for around an hr.
Reading around this means REVO software has reset back to 'stock like' settings which Carl indicates is B1 / T0 / F0
BUT when driving the car it certainly isnt 'stock' like! ok its slower but it still pulls over 20psi and drops back to 15 ish.
(previously stock APR mode was more 'stock' like 10-12 psi)
does everyone else find this?
Im assuming it has definitely dropped to stock mode.
Im now out of warranty but from my perspective my dealer would easily have known its mapped with REVO 'stock' mode, whereas they wouldnt with APR 'stock' mode.
Red ED35 5dr DSG
BLOG | BUILD
Re: stock mode after battery disconnect query
« Reply #1 on: November 02, 2010, 10:18:21 am »
I think the best thing would be to read the values using the SPS, cable and a laptop, assuming you can still do this.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #2 on: November 02, 2010, 10:37:04 am »
There is a 'grace' period which I guess defined by how quickly the remaining current dissipates from the ECU.  As Ian says you would be wise to check with the SPS.
Stu...
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #3 on: November 02, 2010, 10:52:55 am »
sorry guys cant do that (unless I try disconnecting again), have subsequently reloaded via SPS new settings.
Im pretty sure current had dropped enough as the highline reset all figures for mpg/miles etc
Just surprised that stock doesnt seem very stock ....
Red ED35 5dr DSG
BLOG | BUILD
« Reply #4 on: November 02, 2010, 10:56:35 am »
For what it's worth, on my Revo2 K03 GTI 'stock' mode definitely feels stock and much slower.
A very useful feature of Revo if you have a problem and need to nurse the car, especially when combined with D-mode on DSG.
Offline boxxer1973
« Reply #5 on: October 02, 2011, 10:32:41 pm »
Getting the same problem myself with this disconnected the battery and car is low on power. Did you sort it after??
Mk5 golf Gti REVO. stg2+
Milltek | Auto tech | White line | Forge | REVO | KW | Quaife | helix clutch |
Offline boxxer1973
« Reply #6 on: October 03, 2011, 07:33:34 pm »
Spoke to Revo today, part of a safety feature on mk5's, if battery is disconnected the map sets itself to stock/Base values . then needs a SPS unit to reset previous values
« Reply #7 on: October 14, 2011, 04:45:29 pm »
You don't lose your map... You lose the REVO B/F/T settings.
