Author Topic: Tyre pressure's ED30?  (Read 1957 times)
Offline Hendo
« on: November 09, 2010, 06:31:33 pm »
Does anyone know the correct pressure's on the standard ED30 wheels?
It tells me in Bar on the filler cap but i'd like to know the figures?  I had a look at a converter and seems to come out about 37 to 4p psi? Would that be right?
Rich
Offline Golfgirl
Re: Tyre pressure's ED30?
« Reply #1 on: November 09, 2010, 06:54:49 pm »
36 PSI  :happy2:
FOR SALE!
Offline Hendo
« Reply #2 on: November 09, 2010, 06:55:55 pm »
Ok cool 36psi just seemed a bit high to me.
« Reply #3 on: November 09, 2010, 06:56:48 pm »
I use 37psi - I set the machine to read in bars TBH but if you change the units to PSI, it comes up with 37psi. Anyway, these are recommendations. Depending on usage and/or load, you need to change these.
Offline Golfgirl
« Reply #4 on: November 09, 2010, 07:04:02 pm »
Interesting - when I worked it out it came to 36, hence my settings! I set mine on having no load in the back, because I rarely have rear passengers or an overloaded boot.
FOR SALE!
« Reply #5 on: November 09, 2010, 09:05:37 pm »
« Reply #6 on: November 09, 2010, 09:10:22 pm »
Or go to Google and type in
Code: [Select]
convert 2.6 bar to psi. Comes out as 37.7 psi.
Offline Hendo
« Reply #7 on: November 09, 2010, 09:50:17 pm »
37.7 is what I got.  Most of the other car I have had the tyre pressure has been about 33-35
