Author Topic: Slight jurk in 6th  (Read 2535 times)
Offline madman
Slight jurk in 6th
« on: February 17, 2009, 09:20:23 pm »
Went for a qwick spin in the car on the weekend and noticed a slight judder in 6th gear when you put your foot down. Happens around the 2k - 3k mark. also get a power serge when i take me foot off the throttle sumtimes. The car has a bluefin on it took that off and it does not do it then. The car is a gti on a 56 plate :happy2:
Re: Slight jurk in 6th
« Reply #1 on: February 18, 2009, 12:46:15 pm »
Might be worth a call to SC then mate  :happy2:
If in any doubt they'll probably ask you to take it down there for a look? Hope you get it sorted  :smiley:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #2 on: February 18, 2009, 12:51:05 pm »
def worth a call, any dash lights? and its only 6th not in lower gears?
at that point you are coming on full boost , sounds like its backing off on full throttle for some reason.
possible coilpack under higher boost levels etc
Anyone close how can VAG COM the car to read for fault codes?
Red ED35 5dr DSG
BLOG | BUILD
