Author Topic: DSG and Snow  (Read 10236 times)
Offline rsreid2000
DSG and Snow
« on: December 23, 2010, 09:47:54 am »
Been laid up for the last week because of the snow, but tomorrow I have to go out.
I was wondering how people with DSG were getting on in the snow. This will be my first drive in snow/ice conditions in an "automatic".
Any tips/advice would be welcomed.
Offline markymark
Re: DSG and Snow
« Reply #1 on: December 23, 2010, 09:50:49 am »
I too will be breaking my DSG/snow virginity shortly! :scared:
Offline tony_danza
  • -Receive: 112
Re: DSG and Snow
« Reply #2 on: December 23, 2010, 09:53:19 am »
Dead easy, just keep it in drive and slowly take your foot off the brake with no throttle. Once it starts creeping, gently give it more. I had no issues last year, even on PS2s and the ungritted country lanes around my house.
If you get stuck, ESP/traction off helps. Reversing up hills can be easier if you're in real schtuk. A quick left foot dab of the brake will stop a single spinning wheel, transfers power to the other briefly and the resulting jolt can bounce you free.
« Last Edit: December 23, 2010, 09:54:54 am by tony_danza »
Sideways yo!
Offline Sunglasses Ron
Re: DSG and Snow
« Reply #3 on: December 23, 2010, 09:59:31 am »
As Mike says, DSG is probably easier to drive on snow than manual. The creep definately helps when moving off as you very very rarely get any wheel spin..
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: DSG and Snow
« Reply #4 on: December 23, 2010, 10:05:53 am »
Its all been said above but I have found the DSG very very easy to drive in the snow and ice always perfectly smooth clutch control and very early gear shifts up to a higher gear in D make for easy going on the ice and creep is perfect for moving away  :driver:
Offline coolhandluke
  • -Given: 28
Re: DSG and Snow
« Reply #5 on: December 23, 2010, 10:12:07 am »
I got well stuck the other nite & none of the above options helped and ended up having to get a friend to pull me free with his Discovery  :ashamed:
One thing i did find out is that the screw in towing eye has a left hand thread,what would be the reason for that? :confused:
Offline markymark
Re: DSG and Snow
« Reply #6 on: December 23, 2010, 10:14:26 am »
Thanks for the words of wisdom guy, certainly put my mind at rest! :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: DSG and Snow
« Reply #7 on: December 23, 2010, 10:14:50 am »
Ive had no problems with DSG. Definitely easier than a manual.
Harder for it to work loose apparently :happy2:
Offline QD MBE
  • -Receive: 102
Re: DSG and Snow
« Reply #8 on: December 23, 2010, 10:17:06 am »
Feet up and steer - does just nice! :driver: :driver:
Offline amr_rm
Re: DSG and Snow
« Reply #9 on: December 23, 2010, 10:17:33 am »
True
the load pulling on the eye, will cause the towing eye to want to turn in, instead of out so staying tight all of the time
Suprizing how tight one will get if pulling or being towed for a long distance
Offline chowgar
Re: DSG and Snow
« Reply #10 on: December 23, 2010, 10:21:25 am »
I found that with no pressure on the gas it pulled away so easy on the snow and ice were as most manuals on our toad have been spinning all over the show... Told one young lad in a fiat the other day to pull away in 2nd as he was wheel spinning it all over the show... He just looked at me daft...
Offline S2 Ant
  • -Receive: 21
Re: DSG and Snow
« Reply #11 on: December 23, 2010, 10:24:05 am »
Another DSG virgin here and its been nice and easy getting around anywhere, DSG in conjunction with the ESP on and ive not got stuck yet, its been perfect.
As said, just having no feet on the pedals to get things moving then gently applying the throttle and away you go, even when going thru deep stuff its been great
Ant
Offline rsreid2000
Re: DSG and Snow
« Reply #12 on: December 23, 2010, 10:25:18 am »
Starting to feel a lot better about my drive tomorrow.
Re: DSG and Snow
« Reply #13 on: December 23, 2010, 10:27:38 am »
True
Just looked this up.... and its to do with the way that the rope is bound.
Offline mo
Re: DSG and Snow
« Reply #14 on: December 23, 2010, 10:29:15 am »
As said put car into D and let it pull itself away. But on side roads or any icy surfaces where you may need to crawl along in 1st gear just push your gear selecter into manual mode and when your speed gets slow enough it will go into 1st gear.As far as ive seen in D it wont go lower than 2nd gear when slowing down or crawling.
2007 Ed30 Superchips Bluefin Stg 1
RNS510 & MDI
