Author Topic: Mirror dip on reverse(passenger)  (Read 8283 times)
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
Re: Mirror dip on reverse(passenger)
« Reply #15 on: January 01, 2011, 09:30:53 pm »
Is this called progress?  :confused:
Offline golfman
  • -Given: 17
« Reply #16 on: January 01, 2011, 09:41:21 pm »
Sorry to bring this up(AGAIN) but i just need to figure this out
i fitted a new mirror motor to the passenger mirror and then tried it again but as soon as i put the car in reverse the bloody mirror just keeps going up then out a little bit??????????????
i really need to make a video of this to show exactly what is happening!!!
scott
Could it something obscure like the wrong side motor as in if it was turned the other way it might be correct??
Stu its def not on the wrong way round as i have checked with another mirror!!!
scott :happy2:
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline garytc78
« Reply #17 on: January 02, 2011, 08:59:08 am »
What does the gen3 door controller look like and is there somebody near Liverpool with vcds who can scan my car.
Offline chowgar
« Reply #18 on: January 02, 2011, 11:32:07 am »
2005 GTI here...
I have the folding electric mirrors but as far as I am aware not the reverse dip... if I do I certainly haven't found out how to set it up :confused:
« Reply #19 on: January 02, 2011, 11:47:22 am »
You are aware that you have so SET the "dipped mirror position" arent you?
By the looks of it, its set wrong and thats why its going "up then out a little "
Rich
Offline damoegan
« Reply #20 on: January 02, 2011, 12:02:15 pm »
I never set mine, Rich. Just enabled it and worked first time.
Just leave the mirror selector switch on the passenger side...
« Reply #21 on: January 02, 2011, 12:09:30 pm »
Of course... but if its set wrong in the first place it need adjusting! :happy2:
Offline golfman
  • -Given: 17
« Reply #22 on: January 02, 2011, 01:22:14 pm »
Rich i have just fitted a new mirror this morning to the drivers side with the 7 pin plug so that also now has memory in the mirror too,but it still does the same :sad1:
i have tried to adjust it but once its set and then i drive forward i doesn't go back to the driving position it just stays up the way or all the way down :stupid:
scott
« Last Edit: January 02, 2011, 01:45:14 pm by golfman »
Offline golfman
  • -Given: 17
« Reply #23 on: January 02, 2011, 02:00:44 pm »
Here is a video(not the best)
see what you think!!!
scott
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #24 on: January 02, 2011, 02:53:43 pm »
hi Scott
Try it again but drive off. An earlier post said that he had to reach a certain speed before the mirror went back
Cluster and Key coding
Location Great Yarmouth
Offline damoegan
« Reply #25 on: January 02, 2011, 02:55:43 pm »
hi Scott
That is true but by moving the mirror adjust switch th any other setting also puts the mirror back to normal position.
Offline golfman
  • -Given: 17
« Reply #26 on: January 02, 2011, 03:26:44 pm »
hi Scott
Just tried it Ed it does nothing the mirror just stays down!!!
Also with my other keys when i turn off the ignition the mirror moves to the bottom even more :stupid:
but also with this set of keys the mirror sometimes goes to the top :stupid:
scott
« Last Edit: January 02, 2011, 03:36:10 pm by golfman »
Offline Kalpsn2000
  • -Receive: 56
« Reply #27 on: January 02, 2011, 04:35:18 pm »
I have a 2007 56 plate GTI (UK) with Factory Fitted Parking Sensors and Highline Computer with Highline CCM.
My mirror dips but have noticed that it only does it with one of the keys so I guess I need to set it up with the other one.
Instructions I got from another site:
1. put it in reverse
2. put mirror in L position
3. adjust mirror to see curb
4. take it out of L position
5. take out of reverse
(4 + 5 may work other way round)
Not tried it myself as was already set up with one of the keys but will give it a go with the other one.
