Author Topic: HELP: Hood light won't go off and alarm keeps going off  (Read 14208 times)
Offline VWKD
    • VWKD
« on: January 03, 2011, 04:00:27 pm »
Basically what the subject says...
I get message that hood is open and a light on the speedo and giving it a good slam not making it go away. As a consequence I'm stuck at a pub with the alarm going off intermittently ... any help on where the bonnet open switch is or how to lock the car without setting the alarm much appreciated
1971 T2 Camper
1972 Triumph Spitfire MkIV
1999 Passat TDI Running On Chip Fat
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: HELP: Hood light won't go off and alarm keeps going off
« Reply #1 on: January 03, 2011, 04:18:45 pm »
This is a common problem, the switch is part of the latch mechanism for the bonnet.  I believe disconnecting the wire from the microswitch will make it think the bonnet is closed.  Permanent solution (if a squirt of WD40 doesn't work) is to buy a new bonnet latch - ~£30 IIRC.
Note that if the check oil lights comes on while the switch is fubared its likely not to go off after topping the oil off as the system checks if the bonnet has been opened AND the level is higher before resetting itself.
Sepang Blue S4 BE Avant
Offline Russ_leeds
« Reply #2 on: January 03, 2011, 05:22:35 pm »
on the bottom of the b-piller on the drivers side theres a button which disables the alarm
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #3 on: January 03, 2011, 05:37:10 pm »
^ not strictly true - the button only disables the interior sensors / inclination sensor.  I don't think it disables the door / hatch sensors but I could be wrong.
Offline chowgar
« Reply #4 on: January 03, 2011, 06:04:08 pm »
Thought this wa the anti tow alarm?
Offline Russ_leeds
« Reply #5 on: January 03, 2011, 06:11:42 pm »
oh well worth a try i suppose
ill get my coat :sad1:
 :signLOL:
Offline VWKD
    • VWKD
« Reply #6 on: January 05, 2011, 12:03:43 am »
Thanks everyone for the responses much appreciated.
I went and tried to disconnect the microswitch in the pub car park and couldn't get my fingers anywhere near it :sad: Any tips on how I go about disconnecting it?
Fortunately when I was peeing about with it in the car park a space became available near window where we were sitting so was able to park the car there and leave it unlocked/unalarmed. I have since had it in the garage unlocked/unalarmed.
Could anyone confirm that this issue would cause the alarm to go off ?
Only the alarm kept going off at night a week or so ago and the bonnet light 'Hood Open' message was not being displayed then.  It was going off every couple of hours so quite a long time just long enough to get into deep sleep and be rudely awoken  :sad:  I tried pressing them buttons on the b-pillar but made no difference so come 4:30am and my 3rd rude awakening I just left the bloomin thing unlocked on the driveway in hope someone might steal it...
Can't believe there isn't a way you can just lock the bloomin car without the alarm being set.
Anyway I guess my main question here for starters and to hope it solves the alarm going off issue is how do I disconnect that micro switch.. I tried WD40ing the latch pinging it open and shut a few time to no avail and attempted to remove the grill but after removing the 2 torx self tappers at the top guessed it wasn't gonna be that straight forward.
Thanks again
« Last Edit: January 05, 2011, 12:10:25 am by VWKD »
1971 T2 Camper
Offline Gti_Mad
« Reply #7 on: January 05, 2011, 08:34:46 am »
Hello mate the microswitch will b corroded so need a new 1... The plug 2 disconnect the switch is rite next 2 the drivers headlight can get pic's if needed HTH
Dawain
Offline VWKD
    • VWKD
« Reply #8 on: January 05, 2011, 11:50:50 am »
Cool I'll have a look for that when I get home.. If you have a pic to hand then great otherwise I'll have a look first to see if I can spot it.
I presume I have to replace the whole latch to sort this properly ?  Is this tough to replace ?
1971 T2 Camper
Offline njdudsbury
« Reply #9 on: January 05, 2011, 12:21:41 pm »
The micro switch comes out of the mechanism itself as I've done it.
Grill has to come off the get at the mechanism. I've just left the microswitch out and disconnected it.
Dont really need the display to tell me the bonnet is up!
I have seen these switches on ebay but make sure its the right one before you buy. There is a number on the connector I seem to recall.
Hope this helps
WILLZIE
« Reply #10 on: January 05, 2011, 12:27:27 pm »
Only had a quick read, I thought you could lock it manually, (double lock with the key at once), this locks the car but doesnt activate the alarm I think!
Offline VWKD
    • VWKD
« Reply #11 on: January 05, 2011, 12:43:47 pm »
Hope this helps
Thanks for that.. is removing the grill easy ?  I had a brief go last night but couldn't work out how it was secured at the bottom end!
1971 T2 Camper
Offline VWKD
    • VWKD
« Reply #12 on: January 05, 2011, 12:45:10 pm »
Not sure what you are saying here.. am I twisting the key in the lock position twice  :confused:
1971 T2 Camper
WILLZIE
« Reply #13 on: January 05, 2011, 12:55:28 pm »
Sorry, yes!
Just lock it twice in the door with the key, (fairly quickly). The L.E.D should then stay out if I remember.
I'm not by my car so cannot try it, as I too wanted to know how to turn it off while keeping it locked.
Offline Gti_Mad
« Reply #14 on: January 05, 2011, 03:01:14 pm »
Hi mate haven't got a pic 2 hand but Will take 1 also were u located bud??? And my mate works at Vw I will see if he's got a spare switch layin about as that's were I got mine from Wen I did it on my old car
