Author Topic: Feeler - Possible Group Buy on Intakes  (Read 14917 times)
Offline KRL
  • -Receive: 29
Re: Feeler - Possible Group Buy on Intakes
« Reply #15 on: February 23, 2009, 11:52:39 pm »
you should do a K03 and K04 GB, you would get maximum interest and hopefully then maximum discount  :wink:
Great idea  :happy2:
« Reply #16 on: March 06, 2009, 12:05:11 pm »
any news yet  :smiley:
Offline Cochese
« Reply #17 on: March 06, 2009, 04:54:22 pm »
I'd be interested in a k03 intake. :jumpmove:
Pieces of eight!
Offline The wheel man
« Reply #18 on: March 06, 2009, 06:43:40 pm »
depending on cost KO3 may be of interest too.   :happy2:
Do you have to take off the engine cover for this to fit or have they dont it so you can see the system clearly??
APR cat back, ECS Insert
  • -Receive: 453
« Reply #19 on: March 06, 2009, 06:58:26 pm »
Yes, you have to lose the engine cover or do major modifications to it (cutting) for the intake to fit.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #20 on: March 06, 2009, 07:00:17 pm »
It's being worked on  :happy2:
Should have a full update in the next week or so.
Offline KRL
  • -Receive: 29
« Reply #21 on: March 10, 2009, 12:50:12 pm »
Could you tell me what the difference is between the K03 and K04 intake?
Does the BSH intake need modifying to fit the OEM diverter valve relocation on the ED30s?
The reason I am asking is because I am planning to do a K04 conversion on my my K03 so would like to know if the bung in the BSH intake is compatible with the OEM diverter valve relocation or is it only compatible with BSH's own diverter valve relocation?
  • -Receive: 453
« Reply #22 on: March 10, 2009, 02:57:18 pm »
I suspect you will have to email Phil at BSH directly as the oem k04 car is not available in the US.
« Reply #23 on: March 10, 2009, 03:11:09 pm »
KRL - You may also find some helpful info if you visit GOLFMKV forum across the pond : -
http://www.golfmkv.com/forums/forumdisplay.php?f=14
Be prepared for the fact that the forum Moderators over there are far more lax about language etc and that if someone tells you your car is sick they are paying you a compliment!
HTH
Offline KRL
  • -Receive: 29
« Reply #24 on: March 10, 2009, 03:29:19 pm »
Thanks Red and Ballicus.
Actually I already posted a thread on golfmkv.com and I see you have replied as well Red  :happy2:
Offline Cooper
« Reply #25 on: March 10, 2009, 03:38:03 pm »
I'd be interested in a KO3 depending on price!
C63
SQ5
  • -Receive: 453
« Reply #26 on: March 15, 2009, 08:54:38 pm »
Any update on this?
Offline pazz
« Reply #27 on: March 18, 2009, 08:15:43 pm »
1x KO4 for me!
These BSH ones are rated on VWVortex and also golfmkv.com very highly!
They use metal pipework instead of the EVOMS plastic stuff.
Offline pazz
« Reply #28 on: March 18, 2009, 08:36:40 pm »
Are there any details as to the difference's between the k03 version and k04?
Offline KRL
  • -Receive: 29
« Reply #29 on: March 18, 2009, 08:53:55 pm »
AFAIK The only diffeence will be for the size inlet going to the DV.  BSH currently has its own solution for the DV relocation and their inlet size is 1.5 inches.  However the OEM setup in the K04 turbos needs a 1 inch inlet.
Therefore I guess BSH mght be making an intake with a 1 inch inlet for the OEM K04 setup or they might supply a silicone reducer so the intake will work with OEM relocation hardware.
