Author Topic: Tutorial - How to Update RNS-510 Firmware. ***New Links & Firmware*** 19/02/12  (Read 424579 times)
Offline SeanB
Re: Tutorial - How to Update RNS-510 Firmware.
« Reply #75 on: February 04, 2012, 05:18:32 pm »
The links I have put up above work fine. Upgraded my firmware this morning.
1606robin
« Reply #76 on: February 14, 2012, 05:10:23 pm »
hello can anyone help please,
i have a RNS510 1t0 035 680 B, a few weeks ago it started shutting down and starting back up randomly, when it is shut down you can still hear noise coming from inside.
 when it started happening more frequent i deleted the firmware and tried reinstalling a few different firmware versions, but due to it shutting down so much during the install it wouldn't go past at most 65%
after doing this so many times it now will not go past the welcome to volkswagon screen and it still shuts down!
can anyone tell me what the problem is and how to fix it? my reading of forums leaves me to believe it is the mainboard. does anyone know of anywhere i can get it repaired to?
your help very much appreciated, many thanks
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: Tutorial - How to Update RNS-510 Firmware. New Links & Firmware
« Reply #77 on: February 19, 2012, 08:02:51 pm »
Original Post updated with working links and updated Firmware  :happy2:
There is a later 398X firmware but as it only works on B units and higher i haven't listed it.
I thought it needed a HU higher than C?
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
No it's only A that it won't work with. There are a few people with B Units running it fine but as with any firmware there is a risk. There is also a risk with the 398x as it is a Beta. But i'm running it fine although my unit is the equivalent of a D
« Last Edit: February 19, 2012, 09:15:40 pm by vRS Carl »
Offline @ires
Hello! I´m new here!
Need a litle help...
I have the rns-510 in my car, it´s a version C with 2720 firmware.
Can i instal the 3810 version?
The menu languish will still be in portuguese?
I have the new 2012 maps install in it...will i loose them?
Sorry for my bad inglish...  :wink:
Should be fine to use the 3810 firmware. I used the modified version for A, B and C units for my B unit. Quicker start up and different loading screen. Maps have slightly different colours for routes and icons but I found the interface to be more laggy than previous when touching it.
It will wipe maps so you need to make sure you have the updated maps disc.
Offline @ires
Thanks my friend... ;)
I have the maps! Doing it now! Later o will post the resolt... ;)
Offline @ires
Works just fine! ;)
The menu colors are the same? Can i change it?
I still have to load the maps... ;)
Once again... Thanks! ;)
You need VCDS to switch the colour themes but otherwise the menu colours are the same. As I said, it's the map route colours that are slightly different.
Offline @ires
I Have de VCDS cable and software!... I will trie that!  :happy2:
« Last Edit: February 25, 2012, 04:19:42 pm by @ires »
Offline @ires
Maps are on! ;)
I plugd the Vag-com cable and i entered in navigacion... The opcion of menu colors does not apear! I dont Have that opcion!  :ashamed:
« Last Edit: February 25, 2012, 04:12:00 pm by @ires »
Open up VCDS, go into the Navigation controller. Click on the Long Coding Helper button. Move through the bytes until you get to byte 7. You can select between Highline, Premium and Sportsline. Make a change and save it. Then reboot the RNS using the <, >, and i buttons.
I changed mine to Premium because I preferred the more subtle look.
Offline @ires
I will trie it Now! ;)
Offline @ires
Done!...  :happy2:
Premium is the best for me to!  :smiley:
You are the best! :congrats:
Thank You Very much!  :happy2:
