Author Topic: Yet another...Can anyone help with the revo select settings please?  (Read 10462 times)
Offline heavyd
  • -Receive: 29
Re: Yet another...Can anyone help with the revo select settings please?
« Reply #15 on: January 16, 2011, 08:06:28 pm »
doesnt look too promising :sad1: :sad1: :sad1:
Offline jon-tfsi
  • -Receive: 27
« Reply #16 on: January 16, 2011, 09:18:05 pm »
I have a spare MAF here if you would like to try that first. I'm in Guisborough if you can collect it or can post it if its too far for you to travel. Its used but works fine.  :happy2:
GOLF R Mk7
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #17 on: January 16, 2011, 10:51:59 pm »
There is nothing wrong with those.
As long as there isnt more than a 5bar difference that is sustained it's fine. The two bits you have at 5.43 and 6.03 are brief so I wouldn't be concerned.
Edit - Knew i should have read the previous posts :laugh:
Block 032 is your fuel trim. Should be somewhere between -8 & +8 in both boxes  :happy2:
« Last Edit: January 17, 2011, 08:58:39 am by vRS Carl »
Offline PDT
  • -Receive: 142
Offline Sunglasses Ron
« Reply #19 on: January 17, 2011, 10:21:31 am »
How do you get the screen shots from excel up on to the thread Dom?  :ashamed: I'll post some logs of mine to compare if you want?
Offline heavyd
  • -Receive: 29
« Reply #20 on: January 17, 2011, 01:01:02 pm »
Ill do some more logs tonight. New maf on order from stealers. All u need to do is have the logs up on the screen and press the printscreen button on the keyboard. Open up 'paint' then click paste, crop it if you wish, then save it as a jpg file then upload to photobucket etc.
Thanks so far for the help :happy2:
« Reply #21 on: January 17, 2011, 01:31:33 pm »
When I press the 'Print Screen' button it doesn't do anything?  :confused:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #22 on: January 17, 2011, 01:34:31 pm »
You don't need to log.
Just switch on the ignition, fire up VCDS, select engine, click measuring blocks and type in 032. There will then be values in the first 2 boxes. These are what should be within -8 to +8
« Last Edit: January 17, 2011, 01:36:58 pm by vRS Carl »
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #23 on: January 17, 2011, 01:36:02 pm »
It doesn't appear to do anything but it does.
As HeavyD has said. Press Print Screen, Open up paint, Press Ctrl & V (or click paste) and the screenshot will appear. :happy2:
« Reply #24 on: January 17, 2011, 01:49:08 pm »
It actually does exactly what it says. If you want to just copy the active window then press ALT + Print Screen.
« Reply #25 on: January 17, 2011, 01:51:50 pm »
If all else fails, ask the experts..   :happy2:
Can't get it bigger though..  :confused:
« Last Edit: January 17, 2011, 02:10:21 pm by Sunglasses Ron »
« Reply #26 on: January 17, 2011, 04:06:36 pm »
Size isn't everything you know.  :wink:
Just select the section you want and copy/paste into a new paint window.
« Reply #27 on: January 17, 2011, 04:19:26 pm »
Like this.
:booty:  :signLOL:
Offline heavyd
  • -Receive: 29
« Reply #28 on: January 17, 2011, 04:47:10 pm »
Here goes. It seems that the high lambda value in the first column is higher compared to everyone elses logs?
Thanks for the Maf offer jon-tsfi, but after thinking about it, I'd rather try a brand new one to guarantee it isnt the MAF at fault before spending anymore of my hard earned!
If fuel had been leaking, musnt have been much, as my oil was low again!, only put a litre in teh other month :stupid:
Thanks for your logs Ben and hedge :happy2:
Lambda (Idle)   Lambda (Partial)
Self-Adaptation   Self-Adaptation
-6.1   0
-6.1   0
So upon research, the idle is controlled by the primary o2 sensor asell. how easy is this too change?
« Last Edit: January 17, 2011, 06:13:13 pm by heavyd »
Offline PDT
  • -Receive: 142
« Reply #29 on: January 17, 2011, 06:13:08 pm »
the lambda readings are within tolerance (a minus figure means its removing fuel as its running a little rich)  mine were -8 and with the new MAF they are -1.2.
