Author Topic: Retro fitting headlamp washers - bit of advice needed  (Read 24891 times)
Offline animal
  • .:R32
Re: Retro fitting headlamp washers - bit of advice needed
« Reply #30 on: May 13, 2011, 09:16:44 am »
Does the golf use a larger washer bottle for Xenon equipped cars?
5.5L i think, for cars with washers.
I wonder if this applies to the R32. I'm forever running out of fluid, I've always assumed I had a smaller washer bottle because of the amount space the engine occupies.
Offline mortygttdi
  • -Receive: 146
« Reply #31 on: May 15, 2011, 05:25:33 pm »
All xenon equipped golfs use the 5.5 ltr bottle :happy2:
Darren
« Reply #32 on: May 15, 2011, 06:43:59 pm »
Darren
IIRC any mk5 with headlight washers comes with 5.5L tank too.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #33 on: May 15, 2011, 08:23:43 pm »
my standard golf came with 5.5 litre bottle
Cluster and Key coding
Location Great Yarmouth
Offline kippers_cracks
« Reply #34 on: September 23, 2012, 06:06:59 pm »
hi,
i have retrofitted some angel eye projector headlights to my 2004 tdi 2.0 GT and would like to fit some HID xenons to finish it off.
i know under the new 2012 MOT regulations headlamp washers and autolevellers are required to be legal.
does anyone know if someone retrofits these ?
i think its abit above me to do it
thanks
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #35 on: September 23, 2012, 10:21:33 pm »
I have, as have several others
maybe you should put where you are
« Reply #36 on: September 24, 2012, 01:45:42 pm »
Hi
That would be a good start. I am in Bromsgrove Worcestershire but can travel if required
i can see your in norfolk - about 2.5 hours each way which i can do.
Would be interested in supply and fit or fit only as I could source parts from eBay and vw
Many thanks
Ant
« Last Edit: September 24, 2012, 06:30:24 pm by kippers_cracks »
Offline biglad65
« Reply #37 on: February 25, 2013, 04:49:55 pm »
hi are the lift cylinders (jets) the same for the gti and the gt sport bumper also the bumper moldings cheers
Offline alexperkins
  • -Receive: 99
« Reply #38 on: February 25, 2013, 04:50:39 pm »
Jets are the same I believe
Moulding depends on the age of your GT sport and what bumper it has
Offline biglad65
« Reply #39 on: February 25, 2013, 04:51:55 pm »
its a 57 bumper same as gti one with all black down middle
Offline alexperkins
  • -Receive: 99
« Reply #40 on: February 25, 2013, 05:00:33 pm »
Then it will be the same.
Offline Polo6n1600i
« Reply #41 on: February 25, 2013, 05:02:12 pm »
Where does the loom run to?? (im interested in doing this retro fit too!)
Offline alexperkins
  • -Receive: 99
« Reply #42 on: February 25, 2013, 05:02:46 pm »
It runs to the CECM under the steering wheel
Offline Polo6n1600i
« Reply #43 on: February 25, 2013, 05:06:36 pm »
How do i get it up there???
Offline alexperkins
  • -Receive: 99
« Reply #44 on: February 25, 2013, 05:09:09 pm »
I went through one of the grommets above the dash at the back, but theres various grommets you can go through to get it into the car.
