Author Topic: Cruise Control !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11  (Read 7250 times)
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« on: February 14, 2011, 07:31:45 pm »
Well spent 6 hours with EddieNL (Thanks) yesterday trying to get the cruise control work after adding the stalk a while ago (part number 1K0 054 690A)
We tried controllers 1K0 953 549 BP , BD , AK AND BF . All of which did not make the Crusie work correctly. It did work for the one ending BF but then we, or should i say Eddie couldn't get the Steering sorted (Power steering would never return!) . So he suggested that i should call VW and quote my VIN and ask them which controller will make the Crusie work correctly. I called VW Wolsey in Ipswich and after a discussion i was told that it was not possible with the **** stating if the car hasn't got MFSW it will not work........VIN is WVWZZZ1KZ7W****** and is a 2007 Edition 30 Manual with No MFSW and ...Midline (Is that right Eddie?)
Any ideas..... as we reckon the one ending BK will make it work.
« Last Edit: February 16, 2011, 11:32:31 am by garrardrj »
Re: Cruise Control !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
« Reply #1 on: February 14, 2011, 07:34:09 pm »
Should be do-able. I have a 57-plate ED30, manual, no mfsw/highline.
vRStu fitted my cruise control - might be worth having a chat with him? Didn't need a new SW controller or repair wire.
Offline apollo13
  • -Receive: 47
« Reply #2 on: February 14, 2011, 07:38:59 pm »
That is strange...
I know the BC controller has problems with cruise but the others should be fine.
As for not having a MFSW thats utter rubbish!!
BK has SW0101 just like the BF so in theory it shouldn't matter, although its worth a try???
« Last Edit: February 14, 2011, 07:42:48 pm by apollo13 »
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #3 on: February 14, 2011, 07:40:54 pm »
I have the Bc controller as standard so hence it didn't work..........I think to say we were a bit frustrated was an understatement!
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: February 14, 2011, 08:06:20 pm »
When you say you couldn't get CC to work, what were the symptoms??
Stu...
Offline apollo13
  • -Receive: 47
« Reply #5 on: February 14, 2011, 08:11:44 pm »
Did the cruise work with the BF controller but you couldn't get the power steering back???
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: February 14, 2011, 08:22:59 pm »
The issue was that the controllers that I fitted required basic settings for the G85 steering angle sensor. However the car wouldn't accept it. tried both the ABS (03) and steering (44)
As it was getting dark, I put the original one back and that did also require basic settings which did work
Cruise did work with BF, but that was not the problem.
Etka suggests BK or AL for the vin
« Last Edit: February 14, 2011, 08:29:26 pm by Eddie-NL »
Cluster and Key coding
Location Great Yarmouth
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: February 14, 2011, 08:27:20 pm »
Those are a real ball ache to do Eddie, did it for someone last week, in a similar situation.  Perseverance is the key.
Did you login before trying to adapt basic settings?
Stu...
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: February 14, 2011, 08:30:54 pm »
yep I did the log in, even tried changing the slip ring and tried a different G85
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: February 14, 2011, 08:31:31 pm »
I find taking the car for a bit of a drive beforehand helps too.
Stu...
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #10 on: February 14, 2011, 08:45:06 pm »
apollo........yes the cruise worked but eddie couldn't get the power steering back......he did experience full throttle rolling start  acceleration in it though which brought a smile to his face
« Last Edit: February 14, 2011, 08:48:24 pm by garrardrj »
Offline mortygttdi
  • -Receive: 146
« Reply #11 on: February 15, 2011, 07:01:07 am »
Had exactly the same with Snapey's GTI he had the BC originally so I put a F in and it worked perfect, same spec has yours Garrardrj. no mfsw and midline.
The F controller comes on almost all earlier cars that had midline, although the controller is a highline controller.
Darren
Offline Norbreck21a
« Reply #12 on: February 15, 2011, 07:42:06 am »
Has you car got MFSW ? Reason I ask is that although mine is a 2005 build car, it did come from the factory with cruise. When I fitted the MFSW however it wouldn't work. I had to change my module to an AK unit.
Can't remember (as I'm at work) what the Rev is of my original unit but it might have been an "F" like Darren said above, but I still have it somewhere, and you are welcome to it if you want to try. Like I said, it came on my car fitted with cruise as standard from the factory but without MFSW ?
« Last Edit: February 15, 2011, 07:44:52 am by Norbreck21a »
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #13 on: February 15, 2011, 07:57:08 am »
that is great thanks...if you find it let me know
Offline Norbreck21a
« Reply #14 on: February 15, 2011, 08:17:31 am »
I'll have a look tonight for you mate and let you know tomorrow  :happy2:
