Author Topic: Cel light on  (Read 5295 times)
Cel light on
« on: February 28, 2009, 05:43:35 pm »
As expected my cel light has come on from fitting the new exhaust.
I have a couple of questions as i know nothing about this area.
1. can i just get it cleared in VAG com and thats the end of it.  :smiley:
2. if not how do i fix the problem.  :chicken:
3. If i drive round with this light on is it fooking any of my sensors.  :sad:
Cheers for the advice chaps.
Re: Cel light on
« Reply #1 on: February 28, 2009, 05:45:14 pm »
As expected  :surprised:
Why would you expect it after having the exhaust fitted? I haven't had the CEL come on?
Re: Cel light on
« Reply #2 on: February 28, 2009, 05:46:58 pm »
I dont understand how it works but i think it is because your mapped.  :innocent:
Re: Cel light on
« Reply #3 on: February 28, 2009, 05:47:52 pm »
Really? Well that makes two of us as I don't get that either  :signIWS: :signLOL:
Offline WhiteGTI
  • F-A-S-T
Re: Cel light on
« Reply #4 on: February 28, 2009, 05:49:27 pm »
Its because of your CAT, Tom. Setting off the lambda sensor I believe.
Revo turn off the lambda probe (for threshold readings only) when Stage 2 software is fitted. Maybe Bluefin do the same. (because the software is designed to work with a TBE with a sport cat).
2006 E46 BMW M3 - 343hp
Re: Cel light on
« Reply #5 on: February 28, 2009, 05:59:37 pm »
So do you think it just needs the lambda sensor switching off with VAG com.  :chicken:
Offline WhiteGTI
  • F-A-S-T
Re: Cel light on
« Reply #6 on: February 28, 2009, 06:02:52 pm »
You can't turn the sensor off completely. I don't know of Vagcom can be used to turn just the threshold measurement facility thingy off. Hopefully someone will be along soon to clarify. I guess thats the only way Revo could have done it?
I would guess that that's the reason for your CEL coming on.
Re: Cel light on
« Reply #7 on: February 28, 2009, 09:15:09 pm »
you know what i am going to say  :P
MAP IT  :P
Re: Cel light on
« Reply #8 on: February 28, 2009, 09:18:27 pm »
it wont fook it as all a map does is knock it off as it flowing better so does not get as hot any more so dont worry about it so just what i said above  :P
« Last Edit: February 28, 2009, 09:39:11 pm by MAT ED30 »
Re: Cel light on
« Reply #9 on: February 28, 2009, 09:36:38 pm »
Ok thanks Mat.
Lets talk theoretical then.  :laugh:
How would i get the light off if i didnt want to get it mapped.  :grin:
and will it do any harm to my sensors driving round with the cel not cured.  :smiley:
Re: Cel light on
« Reply #10 on: February 28, 2009, 09:40:46 pm »
Ok thanks Mat.
as soon as it cleared with vag com it will come back on pretty quick and i am not sure if you can get rid of it on vag com ie shut it down
Re: Cel light on
« Reply #11 on: March 02, 2009, 04:49:41 pm »
 I can confirm that you need stage 2 to knock the light off the dash as Chris said, but it is not damaging anything which was my main worry so it is staying on.   :rolleye:
Offline WhiteGTI
  • F-A-S-T
Re: Cel light on
« Reply #12 on: March 02, 2009, 05:00:28 pm »
Does it limit performance or anything whilst it is on?? Obviously the car is not in limp mode or anything, but just wondering if because the car knows that something is wrong, that it safeguards itself a tiny bit?
Re: Cel light on
« Reply #13 on: March 02, 2009, 05:04:47 pm »
No not at all, basically on the stage 2 it just switches the back sensor off in the cat, all it is doing is sensing more gases flowing past, the car still runs the same.  :happy2:
Offline WhiteGTI
  • F-A-S-T
Re: Cel light on
« Reply #14 on: March 02, 2009, 05:06:00 pm »
Cool! Glad you got it sorted Tom  :happy2: :smiley:
