Author Topic: Do I have a Chinook landing in my Lap  (Read 2727 times)
Offline roamer1711
« on: March 23, 2011, 08:23:17 pm »
Now the summer is coming I have the sun roof open on full, the reverb is that bad it makes the head lining shake is this normal?
Went in for a Landy came out with a GTI, mid life crysis? me :-)
Re: Do I have a Chinook landing in my Lap
« Reply #1 on: March 23, 2011, 08:24:10 pm »
When you open the sun roof a diffuser should pop up at the front to stop this turbulence!
« Reply #2 on: March 23, 2011, 08:25:02 pm »
This ^^^
  • -Receive: 453
« Reply #3 on: March 23, 2011, 08:29:01 pm »
If you have a 5 door car then crack open a rear windows and all will be better.
Offline roamer1711
« Reply #4 on: March 23, 2011, 08:35:40 pm »
No, its a 3 door and the harmonics are bad from the roof lining, it full on vibrates even with the diffuser. I came from an old clanky Diesel Freelander and the roof lining never moved ,this could brush your teeth as per the adverts. Could be a dealer visit as its only done less than 10000 miles.
Offline 182_blue
  • -Receive: 54
« Reply #5 on: March 23, 2011, 08:46:37 pm »
I dont know about the roof lining shake but my edition 30 was not good when fully open, the only way to solve it was to open the rear window about 1 inch  (the front might have the same effect).
Offline roamer1711
« Reply #6 on: March 23, 2011, 08:51:50 pm »
Luckily over here in the Emerald Isle sunroof days are few and far between. The door window open i have tried, I shall just put it down to the lighter construction than i was used to and turn up the stereo many thanks.
  • -Receive: 453
« Reply #7 on: March 23, 2011, 08:55:13 pm »
You could try stiffening the deflector like some have done in the US...
Offline roamer1711
« Reply #8 on: March 23, 2011, 08:59:38 pm »
Will have a look for that do you have link? many thanks
  • -Receive: 453
« Reply #9 on: March 23, 2011, 10:11:43 pm »
Here is one thread dealing with the issue though the pics in it aren't loading for me.
http://forums.vwvortex.com/showthread.php?2614126
Offline roamer1711
« Reply #10 on: March 24, 2011, 07:12:33 pm »
many thanks. :happy2:
