Author Topic: Surely there should be a recall for the dv?  (Read 2666 times)
Offline Gtiain
« on: March 25, 2011, 05:04:13 pm »
From what I've seen on here most people who have checked their dv's have had a tear in them. Vw revising the part surely is an admission of a fault with the earlier design?
So is the tear a faulty valve or is it caused by misuse? Surely if it's a faulty part then it should be changed FOC?
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Surely there should be a recall for the dv?
« Reply #1 on: March 25, 2011, 05:08:16 pm »
If they did replace them it's unlikely to be a recall as they are generally reserved for serious and safety issues.
It would be a campaign similar to the current coil pack debacle.
Stu...
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #2 on: March 25, 2011, 05:12:20 pm »
I believe the failure is down to wear and tear and so wouldnt be covered, and failure doesnt cause a H&S issue so VW wouldnt be under pressure to rectify the mistake as its not un-safe.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: March 25, 2011, 05:15:55 pm »
I truth I think they probably should have replaced them as there clearly was an issue, equally I don't think you could say that revising the part is an admission of fault as it could be argued it was 'continuous development' of the product.
Stu...
Offline alexperkins
  • -Receive: 99
« Reply #4 on: March 25, 2011, 05:22:54 pm »
Well the fact its changed so significantly means they were aware of the fault  :signLOL:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: March 25, 2011, 05:28:00 pm »
Lots of parts are revised through a cars production life, it doesn't naturally mean they are all faulty though.
Stu...
Offline alexperkins
  • -Receive: 99
« Reply #6 on: March 25, 2011, 05:28:49 pm »
Thats very true. Often things are revised for better efficiency over most things.
Offline Gtiain
« Reply #7 on: March 25, 2011, 05:42:56 pm »
The fact is though that they tear.  Offcourse some things are updated from time to time To improve efficiency etc.
« Reply #8 on: March 25, 2011, 05:53:09 pm »
Lots of rubber things tear.  :wink:
Offline Gtiain
« Reply #9 on: March 25, 2011, 05:55:46 pm »
Unfortunately!
 :signLOL:
