Author Topic: Wiper Blade adjustment  (Read 2631 times)
TimS996
« on: April 08, 2011, 05:49:18 pm »
I seem to have a bit too much downforce on my wipers as they squeak and leave a 'trace' that is quite distracting. this is even after a proper clean.
Any advice for changing the pressure?
Nasir
Re: Wiper Blade adjustment
« Reply #1 on: April 08, 2011, 11:45:10 pm »
I think you can loosen the screws, although it might be that you need new blades.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #2 on: April 09, 2011, 05:37:31 am »
You can slightly bend the arms to take the tension off but it could be as above that you need new blades.
Stu...
TimS996
« Reply #3 on: April 11, 2011, 09:39:12 pm »
Thanks, got new blades on. Thought that could be the problem.
Offline Kalpsn2000
  • -Receive: 56
« Reply #4 on: April 12, 2011, 11:22:57 am »
Did the new blades sort the problem?
TimS996
« Reply #5 on: April 12, 2011, 03:13:35 pm »
No, still leaving the trace marks.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: April 12, 2011, 07:12:47 pm »
Have you taken the wiper arms off?
Cluster and Key coding
Location Great Yarmouth
TimS996
« Reply #7 on: April 16, 2011, 11:37:52 am »
No.
I have tried bending them out ever so slightly now, I'll see if that helps. it looks as if its been this way for a while though, as there are marks on the screen
