Author Topic: Fuel Cut on Stage 1???  (Read 12879 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Fuel Cut on Stage 1???
« Reply #30 on: April 11, 2011, 10:00:03 pm »
Well that's anyones guess to be honest mate.  I would suggest that if you had fuel cut it would be repeatable.
Stu...
Offline johnhol78
« Reply #31 on: April 11, 2011, 10:37:58 pm »
Thanks Stu...
Will keep an eye on it this week. Having some logging done this weekend by mb from here so see what happens with that.
« Reply #32 on: April 11, 2011, 10:44:27 pm »
The GTi is a 97RON car as stock so I'd expect the map to be designed to utilise 97 at a minimum.  Most will expect you to use 98/99 for best results.
But in answer to your original question it is entirely possible to get fuel cut with what you consider to be a stage 1 map.  There aren't really defined parameters for stage 1 mapping so yours could be more aggressive.
I thought the TFSI was 98RON. Pretty sure that's what the fuel flap says.  :confused:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #33 on: April 11, 2011, 10:52:50 pm »
You're probably right Ian  :happy2:
Stu...
Offline alexperkins
  • -Receive: 99
« Reply #34 on: April 12, 2011, 07:25:48 am »
Aye that is what the fuel cap says. I filled up earlier  :happy2:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #35 on: April 12, 2011, 11:52:22 am »
iirc it needs 98RON for the stratifying to work properly...
Diesel Daily Hack.
« Reply #36 on: April 12, 2011, 03:54:37 pm »
That as well.
Offline Homer
« Reply #37 on: April 15, 2011, 09:15:43 pm »
I have of late noticed that at timed when I put my foot down there is a delay and then the turbo kicks in, do you guys think that this sounds like a fuel cut? I have had my DV replaced to the revision D model.
Saint Steve
« Reply #38 on: April 15, 2011, 09:18:55 pm »
May just be turbo lag, i doubt, at stage 1 on your K03 that it would be a fueling issue if youve not fitted any other supporting mods Homer.
