Author Topic: Fitting an Intake  (Read 3623 times)
Offline marka87uk
Fitting an Intake
« on: April 13, 2011, 05:46:15 pm »
Hi,
Is there a guide on fitting an intake anywhere?
I basically just need to know if I'll be able to do it myself or if it's a bit tricky!
Steel Grey Edition 30 DSG
Offline big al
Re: Fitting an Intake
« Reply #1 on: April 13, 2011, 05:48:25 pm »
Depends what you go for, Which you thinking of?
I am a complete dunce when it comes to cars, and I have fitted a BSH intake and a twintake myself.
They are really pretty self explanatory. :happy2:
  • -Receive: 453
« Reply #2 on: April 13, 2011, 05:57:02 pm »
Just get the proper pliers for removing the clamp at the turbo side and everything should be straight forward even for a novice. It's possible to not need the pliers but they really makes the job so much easier.
Offline marka87uk
« Reply #3 on: April 13, 2011, 06:11:10 pm »
Thanks! What do you mean by proper pliers?
I've bought a Neuspeed P-Flo intake. I assume as you say it's fairly easy to fit but I don't want to have any problems! ...And I don't really want to pay garage labour costs if I could do it myself either!
Offline big al
« Reply #4 on: April 13, 2011, 09:22:37 pm »
That's a pretty straightforward one to fit, just unclip the air intake pipe at the rear end, closest to the windscreen.
Remove the sensor, take off the cover, and probably using jubilee clips fix the new one in.
  • -Receive: 453
« Reply #5 on: April 13, 2011, 09:35:36 pm »
A flat band hose clamp pliers like this
Offline marka87uk
« Reply #6 on: April 14, 2011, 06:05:54 pm »
The intake arrived today - looks great! As I bought it second hand I think I made need buy another hose clip to attach it to the turbo... is that correct or can I reuse one that's already on the car?
  • -Receive: 453
« Reply #7 on: April 14, 2011, 07:03:30 pm »
IMO it would be easier to use a jubilee clip.
Offline marka87uk
« Reply #8 on: April 14, 2011, 07:45:56 pm »
Sorry, that's what I meant! What size would I need to attach the silicon pipe to the turbo inlet pipe?
Offline Janner_Sy
  • -Receive: 113
« Reply #9 on: April 14, 2011, 07:49:07 pm »
easiest thing for thr clamps is one of these
absolute doddle to use. http://jbtoolshop.co.uk/pliers-and-mole-grips/long-reach-hose-clamp-pliers
handy tool, as pretty much all cars are loaded with clamps like this so if your into DIY mechanical work they are a great buy
Offline marka87uk
« Reply #10 on: April 14, 2011, 08:45:47 pm »
Ah thanks! Although to be honest I think I'll just struggle this once considering the price of them and how much I'd use them!
Any idea what size jubilee clips I need to attach the silicon pipe to the turbo (K04)?
Offline martziniuk
« Reply #11 on: April 14, 2011, 09:10:45 pm »
I just used needle nosed pliers to take the pipe off the turbo.
Offline marka87uk
« Reply #12 on: April 14, 2011, 10:07:50 pm »
Cheers, sure I'll manage to pry it off somehow!
Found a guide on installing an intake on K04 cars and it looks like I'll need a 50-70mm clip on the side connected to the turbo and then 60-80mm on the side connected to the intake pipe?
Offline keano
  • -Given: 79
« Reply #13 on: April 14, 2011, 10:19:00 pm »
You will certainly need these:
