Author Topic: Porka brakes  (Read 2596 times)
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
Porka brakes
« on: April 16, 2011, 05:57:48 pm »
Guys,
I think a set of porka brakes in red would suit my ed30 like a treat! My question is....who is running a set of these brakes at the moment? Any idea of wich model they would have to be off? Any pictures?
Cheers guys
Jack
www.distinctdetailing.co.uk
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: Porka brakes
« Reply #1 on: April 16, 2011, 06:51:43 pm »
Muckipup on here is running a set of Porker fronts (from a Boxster S iirc)
Main advantage over something like R32/S3 kit is the weight. He put a pic on here holding the caliper with just his little finger. Plus they can use your existing discs.
Do a search for daveB's not quite so big brake kit.
EDIT: Here you go Not quite so big brake kit clicky
« Last Edit: April 16, 2011, 06:55:20 pm by vRS Carl »
Offline Poppa Dom
Re: Porka brakes
« Reply #2 on: April 16, 2011, 09:23:44 pm »
I'm running 996 turbo 4 pots mated with Mercedes R500 discs. On my build thread  :happy2:
Offline berg
  • -Given: 49
  • -Receive: 38
Re: Porka brakes
« Reply #3 on: April 16, 2011, 09:40:11 pm »
yup, got the Dave B brakes mine are off a 07 Cayman, so much lighter than the OEM calipers was unbelievable
Offline JackG
  • -Given: 33
  • -Receive: 31
Re: Porka brakes
« Reply #4 on: April 17, 2011, 09:13:38 am »
So from what I can see the ones of a boxter (4 pots) are not really a BBK as such.......but a good 1 step upgrade, i just like the look of them! They look really good in red, is there 6 pots for porkas about wich discs that are bigger than 30mm thick?
Jack
Offline Poppa Dom
Re: Porka brakes
« Reply #5 on: April 17, 2011, 10:47:01 am »
Discs I run are 350*32  :happy2: but my set up will not run under pescaras unless you run spacers.
Offline Carrera2RS
Re: Porka brakes
« Reply #6 on: April 18, 2011, 10:53:31 am »
There are quite a few Porsche calipers available on e-bay at present.  :happy2:
