Author Topic: Airbag fault  (Read 7049 times)
Offline Gtiain
Airbag fault
« on: April 16, 2011, 08:58:51 pm »
Just started up my car and it says airbag fault?! Anyone got any ideas of what I should do or why it's come up?  Cheers
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Airbag fault
« Reply #1 on: April 16, 2011, 09:20:02 pm »
VCDS to tell you what is at fault and if possible reset it.
Stu...
Offline Gtiain
Re: Airbag fault
« Reply #2 on: April 16, 2011, 09:22:00 pm »
Thanks. What could it be? Is anyone near Bradford who could check it for me? Darrens usually a bit busy now.  :sad1:
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Airbag fault
« Reply #3 on: April 16, 2011, 09:23:07 pm »
Difficult to say Iain, under seat wiring looms have been an issue in the past.
Check the sticky in the VCDS section.
Stu...
Offline Gtiain
Re: Airbag fault
« Reply #4 on: April 16, 2011, 09:27:33 pm »
Thankyou. Is it best to turn it off or what? I'll have to do a bit of driving before I can get it sorted. If so is the the lock in the glovebox?
Offline apollo13
  • -Receive: 47
Re: Airbag fault
« Reply #5 on: April 16, 2011, 09:30:23 pm »
The lock in the glovebox only turns of the front passenger airbag (baby seat).
As Stu has said the under seat connectors are a problem, had the issue on mine after the missus hoovered the carpets  :surprised:
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Airbag fault
« Reply #6 on: April 16, 2011, 09:31:09 pm »
You'll need VCDS to turn off the warning.
Stu...
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Re: Airbag fault
« Reply #7 on: April 16, 2011, 09:39:07 pm »
i had trouble with under the passenger seat airbag plug, i unplugged it gave it some contact oil and plugged it again. No trouble for a year now  :happy2:
Over the top mod list ;o)
Offline Gtiain
Re: Airbag fault
« Reply #8 on: April 16, 2011, 09:42:21 pm »
Whereas the plug and what does it look like?
Offline apollo13
  • -Receive: 47
Re: Airbag fault
« Reply #9 on: April 16, 2011, 09:43:57 pm »
Iain its the yellow one under the seat.
Usually connected in the black lidded box  :happy2:
Offline Gtiain
Re: Airbag fault
« Reply #10 on: April 16, 2011, 09:53:36 pm »
Is there any harm in just driving with the warning light or should I disable the airbag (how do I do that). I mean it's not going to go off if I go over a bump or something is it?!
Offline mortygttdi
  • -Receive: 146
Re: Airbag fault
« Reply #11 on: April 16, 2011, 09:58:28 pm »
Drop by if your in the area mate, I'm not usually busy on sundays.
Darren
Offline no golf clubs at all
Re: Airbag fault
« Reply #12 on: April 17, 2011, 07:21:46 am »
Unbelievably, yesterday I had problems whilst fitting a Bury car kit. Basically I pulled too hard on the top vent section and the only way I could remove it to fit it together correctly was to disconnect all the cables including the airbag warning light.
You guessed it the system detected a fault on power up and I now have the same Airbag waning sign on dash and the obligatory bong. :-(
Will I have to visit a stealership or Indy to remove the fault?
You'd think the system if it's smart enough to detect a problem would be smart enough to detect also when it's working correctly. But it's probably a safety thing I guess.
Offline Gtiain
Re: Airbag fault
« Reply #13 on: April 17, 2011, 08:33:32 am »
Pop round to someone who has vcds. They can see what the fault is, as I'm sure your aware there is a few people on here with it.  :happy2:
Offline Gtiain
Re: Airbag fault
« Reply #14 on: April 17, 2011, 08:44:50 am »
Well my warning light has now gone! Thanks again Darren, your a star!  :happy2:
