Author Topic: Cooked brakes, how do I sort it out?  (Read 22116 times)
Offline jon-tfsi
  • -Receive: 27
Re: Cooked brakes, how do I sort it out?
« Reply #45 on: June 22, 2011, 09:32:50 pm »
Would highly recommend Andy at ACR his knowledge is endless and he only charges about £25 to 30 an hour.
Had been chasing a problem with my car for 6 months at various garages. He figured it out in 30 mins.
GOLF R Mk7
Offline heavyd
  • -Receive: 29
« Reply #46 on: June 22, 2011, 10:15:58 pm »
Wish I had bought those s3 brakes off you the other month, then this mightnt of happened :ashamed:
I'll give him a ring tomorrow and see wht he says :happy2:
Offline chrishalfpenny
« Reply #47 on: June 23, 2011, 05:08:38 am »
I would say in my unbiased view BUY MY FERRARI F40 BBK which is for sale in the for sale section f :happy2:. That will stop you having brake fade cooked brakes (unless your a absolute animal) ever again, and these come with the added bonus of ripping your spin out every time you have to stop very quickly
Offline Powervalve Nige
  • Trader - 2014
  • -Given: 84
  • -Receive: 76
    • POWERVALVE
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #49 on: June 23, 2011, 09:50:16 am »
Nige is that a branded XYZ kit?
  • Trader - 2014
  • -Given: 84
  • -Receive: 76
    • POWERVALVE
« Reply #50 on: June 23, 2011, 10:16:06 am »
No its our kit - note the logo is proud of the casing not counter sunk or machined in ( dead easy way to spot generic castings)
6 pt due out in 4-5 weeks ( toolings cost a fortune  :sick:
Offline muckipup
  • -Receive: 25
« Reply #51 on: June 23, 2011, 03:07:58 pm »
Did you bleed the system with VAGCOM, so it does all the ABS etc too??
Quick question and hopefully not too off-topic but is recycling of the ABS pump with VCDS really necessary? I heard one story about old brake fluid hiding in there but another from a techie I think saying that it was nonsense as the ABS pump was in an 'open' state when inactive such that when pushing new fluid through the system it also pushes through the pump. Can someone clear this up?
If there's a procedure to follow, then it's there for a reason.  :happy2:
I thought it was only necessary to follow this procedure if you were unlucky enough to have a fluid leak that meant the system and the ABS pumps ran dry. Then the ABS pumps need to be cycled to remove air pockets. The guide for VCDS sort of supports this:
http://www.ross-tech.com/vag-com/cars/absbleeding.html
Offline heavyd
  • -Receive: 29
« Reply #52 on: June 23, 2011, 06:36:00 pm »
Our 4 pot kit might be just what your looking for  :happy2:
http://www.bcsautomotive.co.uk/product_description.php?PNo=95
http://www.bcsautomotive.co.uk/photos_listing.php?CatNo=16&CatName=BCS+Pro+Brake+Kits
What is the price on that kit like if you dont mind me asking?
I've got to get my oem setup working properly first before I go BBK.
Thanks andy and john for the recommendation, got booked in at ACR next wednesday :happy2:
  • Trader - 2014
  • -Receive: 130
« Reply #53 on: June 23, 2011, 10:39:33 pm »
It might be the case that your calipers got a bit hot, possibly might recommend a seal change in the caliper.
The seals are square in section but sit within a recess that is rhomboidal, this creates the rollback that withdraws the pad when you take your foot of the pedal.
At the and of the day if you change the pads/discs/fluid/caliper seals then there very little left to do.
« Reply #54 on: June 23, 2011, 11:12:27 pm »
rhomboidal.  Didn't he used to play for Everton.  :rolleye:
  • Trader - 2014
  • -Receive: 130
« Reply #55 on: June 24, 2011, 06:49:13 am »
You're thinking of the Greek Centre Forward Trape Ezium
Offline heavyd
  • -Receive: 29
« Reply #56 on: June 24, 2011, 08:21:58 am »
There's a set of gti calipers on eBay, do you reckon it'll be worth me buying those then dave? I remember the hassle with seals on the lamborghini calipers I bought for my mk4 golf....
Offline PDT
  • -Receive: 142
« Reply #57 on: June 24, 2011, 10:16:21 am »
Have you approached the person that killed the brakes about the issues you are having? They may be able to help out?
« Last Edit: June 24, 2011, 02:01:14 pm by PDT »
  • Trader - 2014
  • -Given: 84
  • -Receive: 76
    • POWERVALVE
« Reply #58 on: June 24, 2011, 11:08:20 am »
We can do the full install for £995.00 or £895.00 supply only
Offline heavyd
  • -Receive: 29
« Reply #59 on: June 24, 2011, 12:58:42 pm »
Have you approached the person that cilled the brakes about the issues you are having? They may be able to help out?
They said they would have a look free of charge, but it was 6 hr round trip and £80 of fuel the last time I went there   :scared:
