Author Topic: Cooked brakes, how do I sort it out?  (Read 21438 times)
Offline 56OctyVRS
  • -Receive: 72
Re: Cooked brakes, how do I sort it out?
« Reply #60 on: June 24, 2011, 06:53:36 pm »
I recently cooked my brakes too and found that after about 500 miles of driving they came back with no problems.  You will get a different pedal feel with performance pads as they are made from slightly different material and not like the OEM ones. I had this on my FRS when I put Black diamond pads on instead of brembo and had to push harder to get the same level of friction.....oh and annoying brake squeel to go along with it as they were almost race pads!  I soon switched back to the brembo pads and all was good again  :smiley:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #61 on: June 24, 2011, 07:10:52 pm »
I've only browsed the many pages but were the OEM pads you bought Pagid??
Stu...
Offline heavyd
  • -Receive: 29
« Reply #62 on: June 24, 2011, 07:52:16 pm »
I had pagids on before, but now done about 450miles on the ds2500s
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #63 on: June 24, 2011, 07:53:33 pm »
Talking to Jim at JKM earlier and he's had a similar issue with his brakes after fitting OEM Pagid pads.  Swapped them out and all was ok.
Stu...
« Reply #64 on: June 24, 2011, 07:54:55 pm »
I'm running Pagids in my R32 fronts and they are great.
Offline heavyd
  • -Receive: 29
« Reply #65 on: June 29, 2011, 02:49:46 pm »
I spent a couple of hours at ACR today, their conclusion was that I need a new master cylinder :confused:
Brakes were rebled, abs pump bleed, everything else checked aswell :sad1:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #66 on: June 29, 2011, 03:33:38 pm »
Said the same thing to me on Monday.
However if you now need a new master cylinder i can't see how logging for a remap would cause that to fail. Might just be a coincidence that it was about to go anyway.
How much is that going to set you back?
Offline PDT
  • -Receive: 142
« Reply #67 on: June 29, 2011, 04:00:58 pm »
Boiled fluid can cause damage to the master cylinder seals, which ties in with the long pedal issue. Also check the seals at the calipers.
Offline heavyd
  • -Receive: 29
« Reply #68 on: June 29, 2011, 04:22:53 pm »
I've been quoted £250 with genuine parts. I thought it might be a coincidence, but as dave pointed out, might be the boiled fluid has damaged the seals :fighting:
« Reply #69 on: June 29, 2011, 04:45:05 pm »
least you have a conclusion on what it is Dom and it will fix the problem--hope you got treat well at acr
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #70 on: June 29, 2011, 08:39:37 pm »
not pleasant but at least you can effect a fix  :happy2:
good luck
Red ED35 5dr DSG
BLOG | BUILD
Offline heavyd
  • -Receive: 29
« Reply #71 on: June 30, 2011, 12:49:02 pm »
just got a set of r32 calipers aswell cheap, at least I can rule out the caliper seals being cooked :evilgrin:
yes andy, nota bad price he charged either :happy2:
« Last Edit: June 30, 2011, 01:17:10 pm by heavyd »
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #72 on: July 12, 2011, 11:50:34 am »
"You get what you pay for."
« Reply #73 on: July 12, 2011, 12:16:05 pm »
I would want to know how a professional tuner has managed to cook your brakes whilst logging  :chicken: I cant see why they would even need to touch the brakes.  :popcornsoda:
« Reply #74 on: July 12, 2011, 12:17:05 pm »
I agree Mr Cat I find that very strange behaviour.  :confused:
