Author Topic: How to activate mirror down function  (Read 13300 times)
Offline flyboy1976
« on: June 12, 2011, 08:31:05 am »
can someone tell me how to activate mirror down function on the pass mirror please. i have VCDS just need to know what to do etc
Fly
Offline CocoPops
    • Kennet Heath
Re: How to activate mirror down function
« Reply #1 on: June 12, 2011, 08:59:29 am »
Its not just a vcds job..
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
Offline 182_blue
  • -Receive: 54
« Reply #2 on: June 12, 2011, 09:06:19 am »
You need folding mirrors for this function, do you have them ?, they have a different motor in them with a memory function, that said very very rarely this part finds its way into a non folding mirror (i guess when they run out of the proper parts they use that one instead).
« Last Edit: June 12, 2011, 09:08:15 am by 182_blue »
Offline flyboy1976
« Reply #3 on: June 12, 2011, 09:08:03 am »
Thanks shaun.....i thought it wasnt that simple lol
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #4 on: June 12, 2011, 09:14:00 am »
I've the mirror down without the folding mirror, thIs not normal?
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline 182_blue
  • -Receive: 54
« Reply #5 on: June 12, 2011, 09:20:25 am »
Generally no its not normal, as i said though a few seem to have got it for some reason, the general rule though (Info from ETKA parts) is the memory function (dipping) comes with the folding mirror part, i even saw where a owner had folding mirrors but never knew as they didnt have the folding switch to operate it  !!, they only discovered it when they took it apart and another forum poster saw the extra wiring that the folding mirrors have in them.
« Last Edit: June 12, 2011, 09:23:35 am by 182_blue »
Offline chowgar
« Reply #6 on: June 12, 2011, 10:20:37 am »
interesting I have the folding mirror but dont think I hae the auto dip.... cant see it inthe standard menu on the high line...
Offline alexperkins
  • -Receive: 99
« Reply #7 on: June 12, 2011, 10:22:27 am »
If you have factory fit PDC (reverse parking sensors) then you get the mirror down function as standard. Mine has it as do a few others that have the PDC from original spec.
Offline mortygttdi
  • -Receive: 146
« Reply #8 on: June 12, 2011, 10:50:40 am »
Just about to say the exact same thing Alex, great minds and all that :grin: Mirror down on early cars was only  available with the PDC, it was never an option with folding that I'm aware of but I could be wrong.
On later cars i.e the mk6 the mirror dip seams to be the norm,
I'm the exception has I think I am the only one to retro fit it anywhere other than giving the info to Scott(Golfman) has he now has it.
It involves a new mk6 door controller with the mirror dip and some basic wire swapping and stuff,
Darren
Offline chowgar
« Reply #9 on: June 12, 2011, 10:55:33 am »
thought my reverse sensor were factory... not sure how you can tell, but cant find anything in the menu to turn on the dipping mirror...
Offline flyboy1976
« Reply #10 on: June 12, 2011, 11:34:50 am »
darren this is on a gt tdi with factory park sensors ....what do i do to activate it please
Offline mortygttdi
  • -Receive: 146
« Reply #11 on: June 12, 2011, 12:06:26 pm »
Like has been said mate not all cars had the mirror down even if PDC was factory, but it can be retrofitted, you can try and enable it in the convenience controller, VCDS it then if you have the highline computer it will show up in there?  then you can turn it on and off.
Darren
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #12 on: June 13, 2011, 07:51:00 pm »
I retro fitted electric folding mirrors and the module needs to have a secondary position sensor in it, every time I code it I get an error to say that Jxxx intermittent connection controller not found, so having folding mirrors doesn't pre-requisite reverse mirror dip, I think from some googling I did it might relate to the mirror motor itself (the half spherical thing you clip the mirror into) having a controller that is able to sense its position and store the co-ordinates in the door controller. but this is all speculation on threads read and experience with my coding attempts.
Offline mortygttdi
  • -Receive: 146
« Reply #13 on: June 13, 2011, 08:00:20 pm »
Your right Rich its the motor that moves the mirror,  My mate had a mk6 Gti breaking and I happened to get the passenger controller and full mirror housing, I needed to add extra wiring into the mirror loom and change some pin outs on the controller and I had full folding with auto dimming and dipping plus puddle lights :happy2:
Darren
Offline Rampage
« Reply #14 on: June 14, 2011, 07:52:31 am »
Hi guys,
I've got the mirror down on my 56 plate ED30. It has folding mirrors but no PDC   :sad1:
