Author Topic: ECU problem continued...  (Read 25829 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: ECU problem continued...
« Reply #15 on: June 24, 2011, 07:31:40 pm »
The only problem is that if the dealer system VAS says your car doesn't need the update then I don't think it will allow them to do it.  If you went to another tuner they should have the correct post 24K6 file which can them be re-calibrated and flashed to the car.
Stu...
Saint Steve
« Reply #16 on: June 24, 2011, 07:33:28 pm »
Bribery then :grin:
« Reply #17 on: June 24, 2011, 07:41:18 pm »
I believe the dealer system could be told to do it but not without plenty of paperwork back to HQ.
Stu's idea should work provided you can find a sympathetic tuner. :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #18 on: June 24, 2011, 07:43:34 pm »
Not even sure you need sympathy Ian, just someone who knows what they are doing.  :evilgrin:
Stu...
Offline PDT
  • -Receive: 142
« Reply #19 on: June 24, 2011, 07:45:12 pm »
Or find a friendly tuner that can update your ECU with new software :smiley:
As for the thing you mentioned about a 700k file, it could be that they are only using part files, but even then it should be a 2048k software with a part file content. I personally dont like part file read/wrire protocols.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #20 on: June 24, 2011, 07:49:11 pm »
Just as a matter of interest Nick, have a look at the service book and under the boot carpet to see if there is anything about 24k6 already being done which might explain why VW think it doesn't need it because it won't be outstanding.
Stu...
Offline keano
  • -Given: 79
« Reply #21 on: June 25, 2011, 01:21:35 pm »
Whoops thought I replied.
The update has already been done guys  :sad1:
What's next you rekon?
Offline keano
  • -Given: 79
« Reply #22 on: June 25, 2011, 01:22:33 pm »
The file put on was 2048, he was very surprised when it came back as such a small file  :scared:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #23 on: June 25, 2011, 01:37:43 pm »
So you have the details in the service book/boot then??
If you've had the 24k6 update at the dealer and then had a remap I wouldn't be surprised if your tuner has loaded to wrong (previous) file back to the car and caused you this problem.  If you go to another tuner they ought to be able to supply the correct file.
Who mapped the car??
Stu...
Offline keano
  • -Given: 79
« Reply #24 on: June 25, 2011, 01:44:13 pm »
Chris from Tuneside. I wrote a review somewhere.
He's the moderator on the golfgtiforum.co.uk
Offline keano
  • -Given: 79
Offline kalu
« Reply #26 on: June 25, 2011, 07:34:10 pm »
This is a known bug with MED9.1 software and VW did release updates to fix it.
**ECU update by Volkswagen (But they don't see any ECU updates on the VW computer  :stupid: )
If you have the part number of your ecu I can tell you what the latest software version is :)
« Last Edit: June 25, 2011, 07:38:45 pm by kalu »
  • -Receive: 453
« Reply #27 on: June 25, 2011, 07:49:05 pm »
I assume he can get the number off vcds...
Offline kalu
« Reply #28 on: June 25, 2011, 07:50:07 pm »
Yes from VCDS or from the ECU Casing.
It will be something like 1K0907115..
Offline keano
  • -Given: 79
« Reply #29 on: June 25, 2011, 09:14:27 pm »
"hi Nick
Your ECU VW part number is 1K0907115L
The bosch hardware number is 0261 S02 429
And finally the current software number is 1037 38 3925
Let me know how you get on!
Chris."
