Author Topic: Neuspeed Hi-Flow Intercooler Pipe, Wont fit?  (Read 2644 times)
Offline james
« on: July 06, 2011, 06:46:59 pm »
Hi all,
I have the THS intercooler( Would this make the problem?),  Went to fit this pipe today but don’t have any clearance, it just sits up against the fans any ideas?
I thought the intercooler went the the other way. :confused:
  • -Receive: 453
Re: Neuspeed Hi-Flow Intercooler Pipe, Wont fit?
« Reply #1 on: July 06, 2011, 06:59:07 pm »
pics...
Offline james
« Reply #2 on: July 07, 2011, 12:16:41 pm »
i got it in today,  but it is like 2mil away from the fans  :surprised:  I hope this will be ok
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #3 on: July 07, 2011, 01:40:28 pm »
You may need to bend the arm that connects the pipe to the Engine block. I had to do this when i had one on mine. It is basically because your intercooler is now a lot thicker (THS are 50mm vs OEM 32mm iirc).
2mm is not enough clearance and you may find the fans rub on the pipe and wear off the coating. This is what happened to mine until i bent the arm slightly which gave it a better fit :happy2:
Offline james
« Reply #4 on: July 07, 2011, 04:42:55 pm »
Took it for a spin, rubs a little.   Do you mean bend the metal arm at the bottom?
Silly question, what is under the coating?  a metal pipe?
thanks  :drinking:
Offline james
« Reply #5 on: July 07, 2011, 05:09:34 pm »
it is so bloody tight,  look at these pics
I have upgraded the engine mounts so the engine should not move to much  :confused:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #6 on: July 07, 2011, 05:45:42 pm »
thanks  :drinking:
Yes bend the metal arm at the part where it joins the engine block so that the pipe sits closer to the engine. Don't bend it too much though and yes all there is underneath is a metal pipe.
Offline james
« Reply #7 on: July 07, 2011, 08:09:49 pm »
thanks i will try bending it tomoz  :happy2:
