Author Topic: Interesting post regarding the D revision DV  (Read 1765 times)
  • -Receive: 453
Offline vRS_Pagey
  • -Receive: 59
Re: Interesting post regarding the D revision DV
« Reply #1 on: August 07, 2011, 08:33:48 pm »
Indeed, I must say from my point of view, even if the rev D is slightly less efficent, I wouldn't know, as my original DV had a sodding great split in the diaphragm.......... :smiley:
Offline martziniuk
« Reply #2 on: August 07, 2011, 10:03:57 pm »
I'll be checking my past logs at some point  :happy2:
« Reply #3 on: August 07, 2011, 10:45:06 pm »
Hmmm, and here I was, thinking that I had wasted my money on a Forge DV (although OEM Rev D wasn't out at the time).
I don't expect that VW are interested in whether performance modders care about their Rev D. VW will have designed it for the common market.
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #4 on: August 08, 2011, 09:11:16 am »
It may be slightly behind but as mentioned in the post it doesnt over boost, also interested to know how the guy did comparitive back to back runs and have different temps.  Also surely there is an element of adaptation for the ECU when you change out the DV as it adapts the map?
