Author Topic: Anyone with a PD140 and vagcom that can help me out?  (Read 1578 times)
Offline PDT
  • -Receive: 142
« on: August 11, 2011, 05:40:06 pm »
I have a car in thats behaving very strangely, I need a member that has a standard(ish) PD140 and vagcom that has 5 mins to spare. Just want to check a value.
Dave@PDT
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: Anyone with a PD140 and vagcom that can help me out?
« Reply #1 on: August 11, 2011, 09:51:33 pm »
Got a 140PD Jetta DSG and a VCDS cable if that helps?
Offline mortygttdi
  • -Receive: 146
« Reply #2 on: August 11, 2011, 10:56:10 pm »
I don't think mine is standard but If I can help I'm here
Darren
« Reply #3 on: August 11, 2011, 11:02:01 pm »
you can scan mine if it helps Dave  but you would ave to come to my works thou
Offline sandancer
« Reply #4 on: August 12, 2011, 07:26:40 am »
I've got a standard 140 2.0tdi, I've only got VAG com shareware though, what value are you needing ? I'm only in South Shields though so I can always drop along to your place if you like. Drop me a line.
h4rdy
« Reply #5 on: August 12, 2011, 03:49:34 pm »
Got a standard 140 Touran that I can VCDS for you.
Offline PDT
  • -Receive: 142
« Reply #6 on: August 12, 2011, 08:57:28 pm »
Wow, tnanks for the replies.
Can you start the engine, go into engine, output tests and activate EGR valve. Need to know if the engine stalls.
And if you like, log the egr requested vs actual and the requested vs actual boost  :happy2:
Sandancer, if we could borrow your car for 1/2 hour I will happily sort you out with some freebies :happy2:
Offline mortygttdi
  • -Receive: 146
« Reply #7 on: August 12, 2011, 10:39:23 pm »
Yes It does Dave Ive tried that before and it stall nearly straight away
