Author Topic: Clock codes and identification (highline upgrade)  (Read 1126 times)
Offline RSam84
« on: August 22, 2011, 06:50:53 pm »
Hi guys ive just pulled the clocks out of my brothers GT TDI, here are the pics of it:
i think this is the important one:
so looking at that id say the code is: 1K092064B.
am i correct? so would i need to swap it with a highline with the code: 1K092074B? will these clocks be ok:
final question how much are we looking for coding them in?!
Cheers from Sam n Joe!
Offline RSam84
Re: Clock codes and identification (highline upgrade)
« Reply #1 on: August 23, 2011, 05:01:09 pm »
Anyone??
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #2 on: August 23, 2011, 08:33:50 pm »
those clocks should be fine as they have the same immo type, as for coding you will need to get a specialist to look at it your best bet is to give Kalu a pm.
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #3 on: August 23, 2011, 09:37:35 pm »
To my knowledge, Kalu is the only guy who can do this. You will need a 974 cluster, the letter after it simply denotes country of origin & that's no real worry. You can change the foil backings in, for example, a US spec temperature display (Fahrenheit) to UK celcius by reusing your old ones.
Now you need to find the corresponding cluster. Get googling!
Offline RSam84
« Reply #4 on: August 23, 2011, 10:26:03 pm »
luckly the 2nd set of clocks pictured are ours already! we saw a cheap set of highline clocks on ebay and bought them with the risk that they would be right and amazingly they were!  :happy2:
just need to get in touch with kalu and sort it out!
