Author Topic: steering wheel controls ?  (Read 9841 times)
Offline ukshaun
  • If in doubt.. flat out
« on: August 26, 2011, 12:23:01 pm »
is it easy to fit steering wheel controls onto a car that hasnt got them as standard?
Has anyone done this?
My progress thread www.mk5golfgti.co.uk/forum/index.php/topic,66117.0.html
Mods done: revo map, new south boost gauge, rcd510 dab, gti grill, gti colour coded valance, tinted lights, leds, gti spoiler
Offline shugyboi
Re: steering wheel controls ?
« Reply #1 on: August 26, 2011, 02:17:23 pm »
there was a post regarding this recently mate. it can be done? what year is your golf?
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #2 on: August 26, 2011, 02:42:27 pm »
It's only easy if you have a DSG car with paddles on the steering wheel. Otherwise no, it's not easy at all :smiley:
« Reply #3 on: August 26, 2011, 02:43:14 pm »
Depends if the car is DSG or not. If it's DSG and has the flappy paddles, the steering wheel spokes are hollow and can be replaced with switches. Otherwise it's a new steering wheel with the buttons already built in.
Offline ukshaun
« Reply #4 on: August 26, 2011, 05:11:52 pm »
cheers fellas, my cars an 08 plate, no dsg or paddles though. so its not going to be a cheap modification then haha
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #5 on: August 26, 2011, 06:31:18 pm »
You'll need a new wheel, slip ring, & most likely new steering wheel controller too. It's a big job :wink:
Offline ukshaun
« Reply #6 on: August 27, 2011, 11:45:27 am »
cheers fella, think i will be leaving that for a while then
Offline apples12
« Reply #7 on: September 06, 2011, 09:45:18 am »
its not such a massive job...
if you already have a 3 spoke steering wheel, then its a fair bit easier as the airbag is the same...
then its just a case of finding the steering wheel from ebay/forum, hunt around in a salvage yard for a steering control module and if your car already has cruise and trip computer, i doubt you'd have to change the slip ring, i didnt and i have a 'basic' 1.9tdi sport model...
MK6 GT TDI  - CW - LUX pack
GONE
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #8 on: September 06, 2011, 10:03:21 am »
you will also need a new airbag wiring harnes as there are two versions basic one for horn and airbag and MF version with an extra wire.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #9 on: September 06, 2011, 06:45:31 pm »
It doesnt have to be expensive, I got my Mk5 MFSW off apples12 for £65 and bagged a Mk6 one for much less than the Mk5 one! Just take your time in collecting the bits! Airbag loom is £25. Slip ring is £30-40. The only expensive thing is the module!
Offline Johnny_tro
« Reply #10 on: September 06, 2011, 10:20:32 pm »
if you have a highline, cruise.....std wheel. is there a way of telling if you have the correct module? or loom wire?
or do you have to take it appart?
Offline apples12
« Reply #11 on: September 07, 2011, 10:03:35 am »
If you've got highline and cruise its quite likely you may already have the correct module, only proper way of checking is to either do a vag com scan, or remove the cowling around the steering wheel and to physically inspect. (unclip the top bit, rotate wheel 90degrees, remove first t20 screw, rotate wheel 180degrees and remove the second one, and the few screws on teh bottom and the lower cowling will be able to be removed. then physically read the full code off the module)
if you don't have a MFSW you will definitely require a new airbag loom because the loom's between MFSW and non-MFSW are completely different.
i found it was quite an 'easy' mod to do, and well worth it in my opinion, only bit i had the garage do was the actual wheel swap because i didnt fancy poking around inside an airbag and i didnt have that fancy 12point bit.
good luck!
GONE
Offline ukshaun
« Reply #12 on: September 07, 2011, 09:22:58 pm »
good luck!
very helpful, cheers mate, theres a few other things id like to do first anyway. such as the rear valance and lower. then ill get a vagcom on it and check it out.
thanks again
Offline marcus
« Reply #13 on: September 13, 2011, 12:11:39 pm »
A bit pricey, but....  http://www.vwcruise.com/22.html
2006 2.0T 5 door GTi
Silver, Xenons, Heated Seats, Cruise, MFSW, 18" Monzas, Lux Pack.
Offline ukshaun
« Reply #14 on: September 13, 2011, 08:18:49 pm »
cheers pal im far too tight for that tho haha
