Author Topic: Project Gadget  (Read 25646 times)
Offline gadget
Project Gadget
« on: April 04, 2009, 09:07:36 am »
Well second visit to my mates at APS on Wednesday.
First on the list was removing the Res section of the Milltek and fitting the straight through
Then we started on the rear suspension by fitting Eibach Springs and Eiback Anti Roll Bars
Now up the front, with new Wishbone bushes. These where replaced with S3 versions which are a solid bush
Springs and Anti Roll Bars also changed up front and while wheels were off we added a unique bit of advertising for APS
Next was a full 4 wheel alignment with front set to neutral and back with a bit of negative camber to help on the bendy stuff
Now drop the ramp down for some bits under the bonnet
Engine cover removed and Forge DV fitted
Engine cover back on with a dry Pipercross installed and a nice Carbon Speed Air intake added
Car handles really well now, exhaust is just right and intake has made a suprising difference.
Lots more to go but have to save up some more pennies first.
Thanks to all the guys at APS Andy, Ed & Nathan for there hard work
Gadget  :driver:
« Last Edit: April 15, 2009, 03:17:37 pm by gadget »
Golf GTi Edition 30-Grey - 5 Door - DSG
APS Re-Map, Milltek Non-Res Exhaust, R32 Brakes, Eibach Springs, Eibach ARB's, Carbon Speed Air Intake, Forge DV.
And much more to come.
Re: Project Gadget
« Reply #1 on: April 04, 2009, 09:31:47 am »
Coming together nicley  :happy2:
How have the Eibach ARB's made a difference to the handling? Oh and just to confirm, when you say you removed the res Milly I take it you just meant the res section and not the whole system?  :confused:
Offline wigit
  • -Given: 129
  • -Receive: 42
Re: Project Gadget
« Reply #2 on: April 04, 2009, 09:33:48 am »
the car is looking good Gadget, you going to get along tomorrows DCO meet, can't fault the APS experience myself, i'll keep my eyes out for it  :happy2:
Offline gadget
Re: Project Gadget
« Reply #3 on: April 04, 2009, 10:15:06 am »
ARB's seemed to have helped body roll, I have got them on the aggressive setting but still not uncomfortable.
And sorry exhaust removed just to take out Res section. :happy2:
Offline WhiteGTI
  • F-A-S-T
Re: Project Gadget
« Reply #4 on: April 04, 2009, 08:43:03 pm »
Excuse my ignorance, but how have you dialled in negative camber at the back, when the OEM mounts aren't camber adjustable? Also, isnt the negative camber meant to come from the front wheels to enable a better turn-in??
 :confused: :confused:
2006 E46 BMW M3 - 343hp
Offline gadget
Re: Project Gadget
« Reply #5 on: April 05, 2009, 09:56:09 am »
The back is adjustable if you look properly and in fact the front isn't so it is just checked.
How it is adjusted is on the inner bolts on the lower arms. The bolts are fitted with offset washers. Also the top arms are adjustable as well. Running negative on the back has a rear steer effect on the back (I think thats right although I could be talking BS)
You can see the upper arm offset washers on this picture
hufcforpromotion
Re: Project Gadget
« Reply #6 on: April 05, 2009, 10:14:53 am »
Looking good mate!
Offline gadget
Re: Project Gadget
« Reply #7 on: April 05, 2009, 01:00:59 pm »
Cheers Mate. Got another set of brakes today so will be painting them up to go on. Hope to get some grooved discs as well.
Jason  :driver:
hufcforpromotion
Re: Project Gadget
« Reply #8 on: April 05, 2009, 01:17:40 pm »
Jason  :driver:
They will look a lot more OEM red! Has to be red on a GTI!
Re: Project Gadget
« Reply #9 on: April 05, 2009, 01:52:36 pm »
Looking very nice  :happy2:
Do you know if APS sell those brake retainer clips as blanks?
Offline gadget
Re: Project Gadget
« Reply #10 on: April 05, 2009, 02:11:55 pm »
Cheers Mate. They are S3 ones painted black so you could do them yourself. It was a little project Andy (APS) and I thought of.
Offline gadget
Re: Project Gadget
« Reply #11 on: April 05, 2009, 02:13:30 pm »
Sorry mate couldn't make it. Andy and Nathan have both had systems off me and I look after them so they look after me in return  :grin:
Offline gadget
Re: Project Gadget
« Reply #12 on: April 05, 2009, 02:18:33 pm »
Jason  :driver:
They won't be red I am afraid. I normally go the OEM route even on my project Touran but this one wont be.
You will have to wait and see but this will be another project
Offline WhiteGTI
  • F-A-S-T
Re: Project Gadget
« Reply #13 on: April 05, 2009, 05:04:26 pm »
Thanks for the reply Gadget, very interesting  :happy2: :happy2:
Offline gadget
Re: Project Gadget
« Reply #14 on: April 08, 2009, 08:24:08 pm »
Delivered Some R32 brakes to APS today for them to work there magic on the colour front should be ready in about a month as you can't rush perfection.
