Author Topic: Autotech HPFP with Revo Stage 1 - SPS Settings  (Read 8931 times)
Offline marka87uk
« on: October 27, 2011, 07:04:59 pm »
Hi,
I'm going to be getting a HPFP fitted with Autotech internals after reading about good gains even without going Stage 2+.
At the moment my Edition 30 just has a Revo stage 1 remap and Neuspeed intake. I assume it'll play nicely with my set-up as others have reported?
Do you think it's worth getting a SPS switch to tweak the Revo settings to account for the new pump or will the ECU adapt automatically? :smiley:
Steel Grey Edition 30 DSG
  • -Receive: 453
Re: Autotech HPFP with Revo Stage 1 - SPS Settings
« Reply #1 on: October 28, 2011, 03:45:03 pm »
The ecu should adapt but you might still be able to increase the boost a notch with the superior fuelling.
NB You should log the car if you change any settings.
Offline marka87uk
« Reply #2 on: November 04, 2011, 07:48:23 pm »
Cheers! :happy2:
I don't have VAGCOM so buying that and a SPS switch just to get a few more ponies will probably not be worth it.
What would I need to log? Fuel rail pressure actual vs requested? I have a phone app with OBD adapter but it only lists fuel rail pressure and I'm not sure if it's requested or actual.
Out of interest what kind of gains are people seeing with a HPFP on stage 1?
  • -Receive: 453
« Reply #3 on: November 04, 2011, 09:53:18 pm »
If the search button would reappear then I would direct you to a post by KRL where he showed that even with stage 1 on a S3 the fuelling is a bit marginal with the oem pump compared to an uprated one.
Offline marka87uk
« Reply #4 on: November 04, 2011, 11:25:53 pm »
Thanks - KRL's original post is below and is very informative however it does not mention actual bhp/torque gains.
http://www.mk5golfgti.co.uk/forum/index.php?topic=14350.0
Offline marka87uk
« Reply #5 on: December 09, 2011, 10:28:25 pm »
I just got a HPFP with Autotech internals fitted and it feels good on stage 1 but prior to fitting I did not have the remap on the car, so going back to it is obviously a big difference, and it's hard to tell what difference of that is due to the HPFP!
I'm going to experiment with BTF settings - I'm thinking B7T4F9 would be a good starting point as I can only really run on 97RON fuel in my location.
I understand I could probably raise the boost more for more low down torque but not necessarily more top-end power. What difference would altering the air-to-fuel ratio cause?
What should I log while testing?  :happy2:
« Reply #6 on: December 09, 2011, 10:33:51 pm »
I wouldn't have thought a uprated HPFP, would make any difference at all if the fuel pressure requests are being met!
Offline gazbutS3
« Reply #7 on: December 09, 2011, 10:46:52 pm »
maybe the requests are met sooner???
I ran the APR pump before going 2+ and there was a deffinate improvement in response
« Reply #8 on: December 09, 2011, 10:50:18 pm »
Revo push the fuel pump even on stage1. You can get good results with a pump.  :wink:
« Reply #9 on: December 09, 2011, 11:15:56 pm »
Hmmm.... does HPFP have a massive effect on MPG?
« Reply #10 on: December 09, 2011, 11:58:08 pm »
Rich - step away from the Ed30.  :signLOL:
« Reply #11 on: December 10, 2011, 12:00:01 am »
PMSL! I can't....
« Reply #12 on: December 10, 2011, 12:15:42 am »
You should. Better things to waste your money on.  :wink:
« Reply #13 on: December 10, 2011, 12:24:30 am »
Such as?
« Reply #14 on: December 10, 2011, 12:31:09 am »
I could say house Rich but I wont.  :wink:
