Author Topic: Big brake kit/NQSBBBK  (Read 3803 times)
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
« on: October 30, 2011, 03:37:48 pm »
Hi guys,
As we all know there are so many different big brake kits on the Market from the R32/S3 set up and the porka NQSBBBK and right up to the forge 10 pots  :drool:
I'm in the market for a new set but I'm stumped! My budget isn't massive...
Lots of searching found me stuck between the porsche kit and the R32 kit purly because of my budget
Pros from my point of veiw of the R32/S3 kit
Rears are vented
Fronts are bigger
Negatives?
Very very heavy?
Don't look amazing compared to the NQSBBBK
Porsche pro's
Look good
4 pot
Lighter
Negatives
Same size as standard?
So I'm stuck! Do I go bigger? Stay lighter (that's we're it counts) more pistons!
I'm after a honest opinion from pepole that may have one or the other or even better.....have had both?
I will do a few track days
What would be best? R32 front and rears or the NQSBBBK with S3 rears all using J hooked discs?
I'll like pure stopping power
Any help would be great  :happy2:
www.distinctdetailing.co.uk
Offline heavyd
  • -Receive: 29
Re: Big brake kit/NQSBBBK
« Reply #1 on: October 30, 2011, 03:53:57 pm »
I think your best bet is to pm tfsi mike, as he has had both kits :happy2:
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #2 on: October 30, 2011, 04:39:09 pm »
I have the nqsbbk and I am thrilled but I can't compare it to the R32 setup (because I didn't have this setup).
But I have a question: why would you like to have the S3/R32 rear brakes? Do you usually have heavy things in the back?
I would use J hooked rotors, Ds2500, steel brake lines and racing brake fluid for the back. I am basing this argument on the fact that (1) I have the nqsbbk and (2) from what I saw on competition cars. I do a few track days per year and there is no need for S3/R32 rears. The Scirocco at Scirocco Cup have ARRacing kits on the front (the big racing kit ~365 rotors I think and 6 pot calipers) and stock calipers and disks (I couldn't find the pad type) on the back. So clearly they don't need more stopping power on the rear (it is true that they have a few pounds less). To make matters even clearer, I saw the the Seat Cupra's from Seat Cup have 256mm disks (compared to the 286mm GTI stock discs) and stock calipers on the rear axle!!!
When choosing the rear brakes it's important to find the right balance. That balance is greatly influenced by the weight on the rear axle and the weight distribution on your car.
Good luck!
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #3 on: October 30, 2011, 05:12:21 pm »
Correct I think there is a balance but surly having bigger rears that are vented reduce heat wich should improve braking? I'm no expert so may be Completly wrong  :popcornsoda:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #4 on: October 30, 2011, 07:12:44 pm »
I would like to see the Forge 10 pots you mention  :wink:
Tarox do 10 pots but not Forge that i'm aware off.  :smiley:
Over the top mod list ;o)
Offline keano
  • -Given: 79
« Reply #5 on: October 30, 2011, 07:23:16 pm »
The S3 brakes look very sexy compared to the Cupra & r32 brakes :laugh: :wink:
« Reply #6 on: October 30, 2011, 07:36:27 pm »
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #7 on: October 30, 2011, 07:54:53 pm »
Tarox, thems the ones!
« Reply #8 on: October 30, 2011, 08:16:07 pm »
YHPM
Guessing you have already read the lengthy NQSBBK thread?
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #9 on: October 30, 2011, 08:53:20 pm »
YHPM
Yes I'm still in the process of it, should have it done by Friday  :signLOL:
Thanks for your advice mike, really appreciate it  :drinking:
