Author Topic: Absolute Disaster  (Read 2881 times)
Offline johnhol78
Absolute Disaster
« on: November 05, 2011, 02:41:37 pm »
Removed, stripped, cleaned my Fuel pump, new cam follower.....installed internals..
Got the pump back on and put the engine cover back and 'crack' The position the diagram shows on the Autotech instructions is wrong, instead of NE direction, my cover has a gap going NW.
Now the car starts....though no acceleration and Fuel Pressure Regulator Valve - Open Circuit - No communication....log.
Awesome.....now I'm screwed as TPS not open and no way of getting a new one.
Can someone tell me if the Valve can be bought separately? If so what am I looking at.
Offline s3dubbin
Re: Absolute Disaster
« Reply #1 on: November 05, 2011, 03:00:00 pm »
Cannot be bought sep. You are not the first....and wont be the last. Stevie.
  • -Receive: 453
« Reply #2 on: November 05, 2011, 03:27:56 pm »
 :sad1:
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
« Reply #3 on: November 05, 2011, 04:19:05 pm »
If its a new pump you need send me a pm :happy2:
www.distinctdetailing.co.uk
Offline johnhol78
« Reply #4 on: November 05, 2011, 04:24:40 pm »
Gutted....need tO be bit more careful next time. New Pump Monday
Offline edd666999
  • -Receive: 89
« Reply #5 on: November 05, 2011, 06:38:15 pm »
Which bit it broke, I have 2pumps in bits, pic?
Offline luckyGti
  • -Receive: 27
« Reply #6 on: November 05, 2011, 06:59:20 pm »
There are a couple of guys with second hand pumps for sale in the classifieds for very little, around £30 iirc.
Offline johnhol78
« Reply #7 on: November 05, 2011, 07:20:32 pm »
It's the Connector on top (Fuel Pressure Regulator Valve....the 32mm nut...
Where you based.?
Offline edd666999
  • -Receive: 89
« Reply #8 on: November 05, 2011, 07:24:59 pm »
I'm in Preston, think I have one of those
Offline johnhol78
« Reply #9 on: November 05, 2011, 07:28:25 pm »
Thanks mate but that's millleeeeesss away.
Seems the same story on here...if it was urgent I would snap your hand off.
Offline vRSAlex
  • -Receive: 253
« Reply #10 on: November 05, 2011, 07:52:04 pm »
The Autotech pic of the sensor orientation is for an A4 engine layout.  I bet loads of people have done the same as you and will continue to until they amend the instructons. As a temp fix, rotate the sensor into the correct position and glue it back together.
Follow AKS tuning on Facebook
Offline johnhol78
« Reply #11 on: November 05, 2011, 08:46:27 pm »
Did as you said though won't fit exactly as before.....two pins come up from sensor into clip...these are in the connector though still won't rev over 4k (in neutral)
Had the cover off....MAF wouldn't could that would it?
Offline vRSAlex
  • -Receive: 253
« Reply #12 on: November 05, 2011, 09:26:39 pm »
Is the car dsg?
Offline johnhol78
« Reply #13 on: November 05, 2011, 10:48:11 pm »
