Author Topic: Alloy help - URGENT!  (Read 7124 times)
« on: April 11, 2009, 06:00:31 pm »
Managed to remove the front offside alloy without problems but the rear one buggered up:
^^^How do I take that disc off so I can refit the alloy?
Offline 182_blue
  • -Receive: 54
Re: Alloy help - URGENT!
« Reply #1 on: April 11, 2009, 06:09:29 pm »
i dont get what you want to remove ?, wont the wheel just go back on ?, thats what the back look like
Offline 182_blue
  • -Receive: 54
« Reply #2 on: April 11, 2009, 06:12:48 pm »
« Reply #3 on: April 11, 2009, 06:18:20 pm »
Nevermind I got it fitted but now that same side sits too high. I can fit my whole fist in the gap between the wheel and the bottom edge of the upper arch.
I couldn't do this before.
What have I f*cked up?
Offline WhiteGTI
  • F-A-S-T
« Reply #4 on: April 11, 2009, 06:19:48 pm »
Take it for a drive and let the spring settle again.
2006 E46 BMW M3 - 343hp
Offline chungster
« Reply #5 on: April 11, 2009, 06:20:24 pm »
i agree with 182_blue.... there's no centre spigots or anything on the std monza's so it just goes straight on against the brake disc.
« Last Edit: April 11, 2009, 06:21:58 pm by chungster »
Offline 182_blue
  • -Receive: 54
« Reply #6 on: April 11, 2009, 06:21:20 pm »
have you released the handbrake yet ?, move the car it will settle
if not just make sure the spring is sat properly (i doudbt its moved though)
« Reply #7 on: April 11, 2009, 06:23:06 pm »
^^^ I didn't have that flat disc thing on the end of the hub when I did the driver's front wheel, which is why I was concerned when I couldn't fit the alloy. Turned out the hub was lower.
Don't know if it was because the jack was leaking and slowly lowering the car or whether the suspension caused it.
I am actually afraid to do so. I sat in the back and moved up and down and it didn't have any effect.
Dammit why does everything I do have to be more complicated than it is for anyone else?!?!?!  :fighting:
« Reply #8 on: April 11, 2009, 06:24:07 pm »
Yeah I released the handbrake and the clutch and let the edge slightly [very slight gradient] but still flipping high. It's like a 4x4 at the back!  :scared:
Offline 182_blue
  • -Receive: 54
« Reply #9 on: April 11, 2009, 06:26:50 pm »
^ just make sure spring is sat right then go out in it, ps what have you been doing to it (im guessing painting and nothing else)
« Reply #10 on: April 11, 2009, 06:28:32 pm »
Yup - nothing else. I don't have the knowledge or experience (or courage) to try anything else.
Going out. If I'm not back in fifteen minutes, assume the worse.
Offline snapey
« Reply #11 on: April 11, 2009, 06:33:15 pm »
I wouldn't worry mate, just give the car a bit of time to settle, same happened to me when i re-fitted mine.
Just take it out for a good blast and she'll be right as rain  :happy2:
If you have to ask why, you'll never understand.
« Reply #12 on: April 11, 2009, 06:39:37 pm »
Well I'm back. I survived.
Moved the car about a foot and I could feel the back end settle. Then took the car out for a spin to make sure the bolts had been correctly tightened with the torque wrench.
Enough adrenaline, fear and hassle for one day. What time does the sun rise these days?
Offline WhiteGTI
  • F-A-S-T
« Reply #13 on: April 11, 2009, 06:49:29 pm »
Phil Mcavity
« Reply #14 on: April 11, 2009, 07:25:53 pm »
6.12am easter sunday, now thats dedication stealth  :happy2:
