June 21, 2026, 02:23:05 am
All Things Mk5
Technical Workshop
Retrofit Washers Golf MK5
Topic: Retrofit Washers Golf MK5 (Read 2482 times)
Shammyy786
Just Arrived
-Given: 2
-Receive: 0
December 02, 2011, 09:33:54 pm »
So carrying out the retrofit washers for my MK5, Anyone be able to help with part numbers and also how I should wire up the inside, more relevantly do i install a new pump system?
Cheers guys
damoegan
Just look at my post count
-Given: 7
-Receive: 33
Re: Retrofit Washers Golf MK5
Reply #1 on:
December 02, 2011, 09:47:34 pm »
Your car came with no windscreen washers
Damien
- My ED30
http://www.mk5golfgti.co.uk/forum/index.php/topic,19610.0.html
Shammyy786
Just Arrived
-Given: 2
-Receive: 0
Reply #2 on:
December 02, 2011, 09:55:11 pm »
lol haha, it did!! but dont I need to install another pump that is compatiable with the washers and stay with the wipers too?...
skard
-Given: 5
-Receive: 245
My Ride:
Reply #3 on:
December 02, 2011, 10:07:36 pm »
There's a list of parts here
http://www.mk5golfgti.co.uk/forum/index.php/topic,10291.0.html
Here's an idea of how it is routed
http://forums.vwvortex.com/showthread.php?4146014
Don't forget you'll need a wiring loom from Kufatec and VCDS to enable it and also low washer level warning.
damoegan
-Given: 7
-Receive: 33
Reply #4 on:
December 02, 2011, 10:27:44 pm »
Darren (mortie) is your man to ask as he has done it to his..
Damien
- My ED30
skard
-Given: 5
-Receive: 245
My Ride:
Reply #5 on:
December 02, 2011, 10:36:43 pm »
When I did it I routed the wiring in from the drivers side where there's a grommet nicely positioned near where you want wires to go (you'll have to remove the wiper arms and scuttle panel) as I doubt the loom is long enough to go via the grommet behind the battery.
All Things Mk5
Technical Workshop
