Author Topic: NGK Iridiums BKR8EIX ***12k mile update on page 13***  (Read 132611 times)
Offline 56OctyVRS
  • -Receive: 72
Re: NGK Iridiums BKR8EIX
« Reply #165 on: July 17, 2012, 04:03:16 pm »
Since refitting the 7s my mpg has gone back upto 37ish on a run. I could barely get above 30mpg with the 8s fitted on a run. The engine is running smoother now and seems to pull better. I think for normal driving the 8s are probably a bit too cold. When I removed them they were fouled so they werent getting hot enough to burn of the carbon deposits.
Saintsteve
« Reply #166 on: July 17, 2012, 05:12:30 pm »
I found the same . Better on 7's then 8's too.
Offline gigolo456
« Reply #167 on: July 23, 2012, 11:46:43 am »
I fitted these Iridium 7s about 10 days ago, after having Platinum 6's for the previous 16 mths. To be honest, i'm not sure if i will stick with the 7s!? Maybe it's just me, but i've found it takes 2 or 3 turns to start in the morning now; with the 6's it started 1st time hail, rain or snow! This morning (last used on Saturday) it took about 3 turns AND started quite gingerly, does anybody else have this?? It just seems ironic that all this started IMMEDIATELY after upping to the 7's...... :sad1:
Andrew
  • -Receive: 453
« Reply #168 on: July 23, 2012, 12:03:35 pm »
Andrew
Out of interest, how old is your battery?
Offline gigolo456
« Reply #169 on: July 23, 2012, 12:11:53 pm »
Well bought my GTi new back in April 2005, so a bit over 7 years....??   :confused:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #170 on: July 23, 2012, 01:07:40 pm »
I know there meant to be pre-gapped, but did you check the gap was correct before install?
Offline gigolo456
« Reply #171 on: July 23, 2012, 01:22:51 pm »
had them fitted by an independent VW, etc Specialist and as far as i know, they were 'gapped' at the standard 0.8mm, which apparently is supposed to cover 99.99% of situations. Wondering though, although wouldn't even know how, if i should change the gap!!??  :confused:
« Reply #172 on: July 23, 2012, 01:30:21 pm »
....If they work, don't mend them! I don't think that changing the gap should be done unless by an expert with the right tools. If the gap is not what it's supposed to be, then wouldn't you feel that something is wrong and needs mending?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #173 on: July 23, 2012, 01:39:50 pm »
^^^ not sure if you read the earlier post Robin, but think that's the point, he's having trouble starting the car.  :innocent:
Offline gigolo456
« Reply #174 on: July 23, 2012, 02:03:56 pm »
cheers Freedy, yes, if i leave the car for more than 24hrs, it's slow in starting, totally different to how it was with the Platinum 6's. I wonder if it's got anything to do with the fact that the car had a custom map 5 wks ago whilst the 6's were still in!? Just seems a huge coincidence in my eyes anyway that i've only had starting problems since upgrading to the 7's...  :sad1:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #175 on: July 23, 2012, 02:52:23 pm »
Who fitted them? Are they tight?
Diesel Daily Hack.
  • -Receive: 453
« Reply #176 on: July 23, 2012, 02:54:24 pm »
My money is on the battery coincidently failing...
Offline gigolo456
« Reply #177 on: July 23, 2012, 03:24:34 pm »
I had them fitted by a very reputable independent specialist in S. Yorkshire, so can't imagine they weren't fitted correctly and/or tightly, although i wouldn't have a clue how to check tbh!!?? Ref the battery, how does one check the life left in one of these??  :rolleye:
  • -Receive: 453
« Reply #178 on: July 23, 2012, 03:32:06 pm »
Do you have a multimeter to check voltage?
If not somewhere like Halfords can check it for you.
Offline gigolo456
« Reply #179 on: July 23, 2012, 03:37:30 pm »
might actually get it checked tomorrow, just in case, just seems a bit of a coincidence that it happens now that i have changed my plugs....
Andrew
