Author Topic: Will these fit?  (Read 6168 times)
Offline ollie288
Will these fit?
« on: April 15, 2009, 12:03:47 am »
Hi
The specs are:
8.5x18 ET32 5x112pcd
^ok ^?? ^good
Ive have seen people run wheels with this offset but would these be ok?
What problems do offsets cause?
Ollie
Offline ollie288
Re: Will these fit?
« Reply #1 on: April 15, 2009, 12:05:41 am »
By the way I have a 1.6 fsi mk5 :drinking:
Offline icenutter
Re: Will these fit?
« Reply #2 on: April 15, 2009, 07:51:12 am »
Counter intuitively, the less the offset the further out the rims will sit.  So if the standard rims were ET50, then some ET32 will sit 18mm further out.
Get all your sports nutrition products here; http://www.myprotein.co.uk and use the code MP73153 to get 5% off your first order.
Offline BeezerDiesel
  • -Given: 33
Re: Will these fit?
« Reply #3 on: April 15, 2009, 09:11:40 am »
Also the rims are an inch wider than standard mk5 18'' wheels, so with such a low ET I reckon the fronts at least will be a problem.
Andy
7R
Offline markymark
Re: Will these fit?
« Reply #4 on: April 15, 2009, 09:19:41 am »
Offline gazbutS3
Re: Will these fit?
« Reply #5 on: April 15, 2009, 09:20:24 am »
they will stick out 30mm more than std :happy2:, will be a problem
Offline The wheel man
Re: Will these fit?
« Reply #6 on: April 15, 2009, 12:18:22 pm »
Yup, pushing that offset on that width.....  although nothing's impossible  :wink:
APR cat back, ECS Insert
Offline jonnyc
  • Herrooooo!
Re: Will these fit?
« Reply #7 on: April 15, 2009, 12:19:26 pm »
You would clear ok if you run a reasonable amount of camber plus 215 tyres, otherwise you would have to be high, and being high looks s*it :happy2:
Re: Will these fit?
« Reply #8 on: April 15, 2009, 12:21:32 pm »
oh i dunno..
 :evilgrin:
Re: Will these fit?
« Reply #9 on: April 15, 2009, 12:39:35 pm »
 :grin:  Excellent
Offline Jaywoo-GTI
  • -Given: 38
Re: Will these fit?
« Reply #10 on: April 15, 2009, 02:09:38 pm »
Anyone know what the width and ofset of 18" BBS Monza 2's are?
Offline gazbutS3
Re: Will these fit?
« Reply #11 on: April 15, 2009, 03:06:33 pm »
originals are 7.5" and ET 51
Re: Will these fit?
« Reply #12 on: April 15, 2009, 04:35:00 pm »
and Monza II copies are usually 8" wide and 45 offset......and not as good in terms of build quality. :wink:
Offline ollie288
Re: Will these fit?
« Reply #13 on: April 15, 2009, 05:46:39 pm »
So they would be a problem. Do you think I could roll the archs and pull them to allow them to fit. I will be lowering it but nothing extereme hust a healthy drop.
Re: Will these fit?
« Reply #14 on: April 15, 2009, 06:08:16 pm »
Like Jonny says  you will need to run a bit of stretch and camber, so unless these wheels are your dream wheels then i personally would find some others more suited.  :smiley:
