Author Topic: Part number help for lost clip  (Read 1598 times)
Offline pazz
« on: December 07, 2011, 11:01:45 am »
I've lost a clip whilst removing a piece of trim from the drivers side footwell.
The clip threads on to a screw which can be seen here.
It then slides on to the back of a piece of trim which sits right next to the accelerator pedal, The trim acts almost as a footrest.
If anyone could take a look on ETKA or knows the P/N that would be fantastic. The parts guy at my local dealer can't find it and assumes it must be part of the trim P/N. The car is a 2007 ED30.
« Last Edit: December 07, 2011, 11:04:29 am by pazz »
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Part number help for lost clip
« Reply #1 on: December 07, 2011, 11:46:12 am »
Found the little blighter  :happy2:
1K0 864 247  0.37p
Offline pazz
« Reply #2 on: December 07, 2011, 12:01:23 pm »
Fab5Freddy,
Thanks pal for having a look but is that the clip listed as no 35 on the diagram of the lower A-pillar drivers side? If it is I've ordered that one and it's not the right clip cause the one I'm after is plastic. 1K0 864 247 is a metallic triangular clip similar to those used on door sill trims.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: December 07, 2011, 12:17:26 pm »
Yeah number 35
Thought that was the one :sad1:
The only other clip i can see is N 902 577 03
Might be worth a shot
EDIT** Also just found N 106 567 02 ( NO. 51 ) looks more like the plastic clip you describe  :happy2:
« Last Edit: December 07, 2011, 12:19:14 pm by fab5freddy »
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #4 on: December 07, 2011, 12:28:45 pm »
Failing those two, i think you're parts guy might be right
could very well come with the piece of trim :sad1:
Offline pazz
« Reply #5 on: December 07, 2011, 12:43:10 pm »
I've had a look at the two you've mentioned in post no 3 but one of them is just a cover and the other is the bolt itself in the floor plan.
I've ordered the trim on the premise that if it doesn't include the clip they won't charge me for it.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #6 on: December 07, 2011, 01:39:24 pm »
Hope you get it sorted  :happy2:
Sorry i couldn't be more help  :sad1:
