Author Topic: rear break lights??  (Read 6238 times)
Offline joesgti
  • Eat my sick, Eat my sick.
rear break lights??
« on: April 15, 2009, 07:37:44 pm »
All this talk about the rear break light in the spoiler got me thinking of something billy was saying at the EVO drive!?
He mentioned the rear break llights being programmed through VagCom to light up as the full circle instead of half circle!? kind of like a skylines!
i think it would look cool if it could be done!  :party: does anybody know??  :smiley:
Offline billyboy
  • Billy lar
Re: rear break lights??
« Reply #1 on: April 15, 2009, 10:21:58 pm »
No not VAGCOM joe, it was summit on a yankie site/vortex,
a wire soldered over 2 points in the light board, i did it myself but the ''bulb out'' came on, plus then i read that it didnt work on 56reg cars only some earlys
i will have a scout about for it again, it went under the heading of 'full circle brake lights'
bill
Offline RunRabbit
« Reply #2 on: April 15, 2009, 10:26:27 pm »
Are the bulbs capable of this?
I thought the ones that are brake and lights are twin filament jobbies and the other half are just normal bulbs, some clever wiring and the right bulbs/holders could make it possible
Offline v2brett
« Reply #3 on: April 15, 2009, 10:39:21 pm »
n
no iirc the bulbs are single filament and the car does some magic and makes them brake lights when you brake  :happy2:
Still Here!
Offline RunRabbit
« Reply #4 on: April 15, 2009, 10:46:38 pm »
n
Should just be a case of some trick wiring then  :happy2: might need a resistor if it's throwing a bulb out warning
Offline v2brett
« Reply #5 on: April 15, 2009, 10:52:14 pm »
yeah sounds like it could be a resistor jobbie, i might give it ago myself  :scared:
Still Here!
« Reply #6 on: April 15, 2009, 10:57:11 pm »
i remember reading about it and you had to put a resistor oo the light ..can't remember where i rear it thou
Offline RunRabbit
« Reply #7 on: April 15, 2009, 10:59:57 pm »
Wiring the lights in parallel will half the resistance so it should only need a 2.5 ish ohm resistor
Offline Pintman
« Reply #8 on: April 16, 2009, 04:26:42 pm »
 Take a look at this:  http://uk-mkivs.net/forums/p/145191/967821.aspx#967821
Looks pretty easy but people say that the "bulb out light" comes on.
« Reply #9 on: April 16, 2009, 04:50:51 pm »
hazard flashing under heavy braking sounds pretty good too
Offline billyboy
  • Billy lar
« Reply #10 on: April 16, 2009, 10:07:04 pm »
Thats the one, ta pintman
yeah my ''bulb out'' came on, so i un-soldered it
billy
Offline joesgti
« Reply #11 on: April 17, 2009, 09:04:52 am »
cheers for the info, think il just leave them  :laugh:
Offline Jaywoo-GTI
  • -Given: 38
« Reply #12 on: April 17, 2009, 09:16:59 am »
This mod would look awesome along side the 4 circle mod linked below.
http://www.golfmk5.com/forums/showthread.php?t=73923
« Reply #13 on: April 17, 2009, 01:08:49 pm »
The other issue is whilst the brake light is on it can 'drown out' the indicator if you are waiting to turn...............
« Reply #14 on: April 17, 2009, 01:12:45 pm »
mine does that standard!
