Author Topic: Help needed, Please  (Read 4560 times)
Offline GLIDN
Help needed, Please
« on: December 15, 2011, 02:52:14 am »
long story short, I attempted a midline to highline cluster swap. It did not work so re-installed my original cluster.
Now I have a few errors, G85 Basic settings lost, G200 basic settings losts, TPMS keeps flashing on the dash, No Power steering, Power assist lost basic settings. Any idea's about the EVAP error would be great too.
I will post my report from VCDS 11.11, afterwards the links I have tried to get this to work. Still no further to a resolution, Don't want to have to send the car into the stealerships unless it has to go.
Don't worry about the CD changer error or Xenon error. Waiting for new D2S bulb and igniter from VW at present. CD changer coding was due to trying to get AUX working on an RCD300.
VCDS Log
Thursday,15,December,2011,13:47:04:44293
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN:            Mileage: 90760km/56395miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW:
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0D1262564
   Coding: 0403000318070160
   Shop #: WSC 63670 981 92918
   VCID: E3CEE1A7224E276
1 Fault Found:
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 90735 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:18:50
             Freeze Frame:
                    RPM: 826 /min
                    Load: 28.6 %
                    Speed: 0.0 km/h
                    Temperature: 82.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
Readiness: 0000 0001
Address 03: ABS Brakes      Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   Shop #: WSC 00046 412 00000
   VCID: 3A70FCC3754486E
3 Faults Found:
01487 - System Function Test
            000 -  -  - Intermittent
01486 - System Function Test Activated
            000 -  -
00810 - Sensor 1/2 for Brake Pressure
            005 - No or Incorrect Basic Setting / Adaptation
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 67D675B75676CB6
No fault code found.
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001342101
   Coding: F78F0F0600041800001400001400000000187F075C
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00049109
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00480286
   Shop #: WSC 00000
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
            010 - Open or Short to Plus
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 3J AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD00JYHR
   Coding: 0013130
   VCID: 2E58C093B90C5AE
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 021 0050
   Coding: 0000042
   VCID: 356AEFFF5C5A696
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 860 E
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0005503
   Shop #: WSC 00090 824 59817
   VCID: 3064DEEBA3384CE
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 200910F2001169
   Coding: E9817F0600020200000003
   Shop #: WSC 12345 321 54321
   VCID: EDDA879FF48A616
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0812
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1K0 959 701 G
   Component: Tuersteuergeraet 09 0148
   Coding: 0000054
   Shop #: WSC 00046 000 00000
   VCID: 3260D4E3AD347EE
Address 44: Steering Assist       Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.0       1502
   VCID: 3162DBEFA832456
1 Fault Found:
02546 - Steering Limit Stop
             Freeze Frame:
                    Mileage: 720 km
                    Temperature: 43.0°C
                    Voltage: 14.20 V
                    Voltage: 13.90 V
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BN
   Component: 01 KSG              0301
   Coding: 9AC802087F2D8404089F01E010
   VCID: 7DFA37DF24EA716
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
   Part No: 1K0 959 702 G
   Coding: 0000054
   VCID: 336ED1E7522E776
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0002
   Coding: 0000003
   VCID: F4EC92FB97A0B0E
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 R
   Component: Radio GR0       019 0023
   Revision: 0001905S    Serial number: VWZ2Z2F2147901
   Coding: 0040402
   Shop #: WSC 00028 028 00001
1 Fault Found:
00857 - CD Changer Unit (R41)
            004 - No Signal/Communication
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
End   ---------------------------------------------------------------------
The Links I have tried to repair issue's,
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist#Steering_Limit_Stop_Adaptation
http://wiki.ross-tech.com/wiki/index.php/02546
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60)#Coding
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60)#Basic_Setting
Thanks for any help that can be provided.
« Last Edit: December 15, 2011, 02:55:04 am by GLIDN »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Help needed, Please
« Reply #1 on: December 15, 2011, 06:22:08 am »
You have started the  function test and that needs to be finished.
Then you need to start basic settings for the G85 and G200
Lateral Acceleration Sensor (G200)
Prerequisites:
System voltage at least 12.0 V.
[Select]
 [03 - Brake Electronics]
 [Measuring Blocks - 08]
 Group 004
 [Go!]
 Check field 2, the value has to be between -1.5 and +1.5 m/s².
 [Done, Go Back]
 [Coding-II - 11]
 OR (if Coding-II is not available)
 [Security Access - 16]
 Enter 40168, to enable the basic setting.
 [Do it!]
 [Basic Settings - 04]
 Group 063
 [Go!]
 Activate the Basic Setting.
 [ON/OFF/Next]
 After a successful basic setting, field 2 should say "OK".
 [Done, Go Back]
 To make sure the basic setting was succesful, check the sensor again.
 Group 004
 [Go!]
 [Done, Go Back]
 [Close Controller, Go Back - 06]
Then for the G85
Sensor for Steering Angle (G85)
Prerequisites:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left.
Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
 If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
 Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
[Select]
 Group 004
 [Go!]
 Check field 1, the value has to be between -1.5 and +1.5 °.
 [Done, Go Back]
 [Coding-II - 11]
 [Do it!]
 Group 060
 [Go!]
 [Done, Go Back]
Note: After successful basic setting, the Steering Limit Stop needs to be adapted too.
Cluster and Key coding
Location Great Yarmouth
Offline GLIDN
« Reply #2 on: December 15, 2011, 07:46:39 am »
Thanks for that Eddie-NL,
What is the function test you are referring too?
I have done all the settings you have posted a few times. No success.
So I guess I'll have to get the function test completed too.
One other thing is the TPMS light on the dash keeps blinking too.
Thanks for the help thus far.
Offline GLIDN
« Reply #3 on: December 16, 2011, 11:03:37 pm »
Well the steering assist and ABS now works, but the TPMS still keeps flashing,
And ESP still does not work. I scanned the car these errors remain.
   Coding: 0004738
1 Faults Found:
According to Ross-tech I need to run the G200 adaption,
I can login in "coding-II" no problem.
When I select coding - 04
Group 063 - go
It reads fine as soon as I Click "on/off/next" I just get presented with an error.
Offline GLIDN
« Reply #4 on: December 18, 2011, 07:06:26 am »
I'm guessing here, but that is the lateral sensor in the SWCM? so by upgrading my steering wheel control Module.
As I want MFSW, This might be able to sort it out?
Only I guess here, but then the error does show in ABS thou.
