Author Topic: Fitting rcd-510.......  (Read 2087 times)
Offline Stevenebm
« on: December 22, 2011, 02:04:01 pm »
Alright chaps.going to fit my rcd 510 tommorow but before I rip out old unit do I need and different connectors for the rear or is it plug and play.don't want to take it out to find I need to order something to make it fit.thanks.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Fitting rcd-510.......
« Reply #1 on: December 22, 2011, 02:12:41 pm »
only the twin antenna adaptor
Cluster and Key coding
Location Great Yarmouth
Offline Stevenebm
« Reply #2 on: December 22, 2011, 02:25:31 pm »
Don't mean to be a pest eddie but got any links so I know I'm buying right thing.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Offline Stevenebm
« Reply #4 on: December 22, 2011, 02:40:48 pm »
Thanks mate. :santa:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: December 22, 2011, 02:46:54 pm »
make sure you try the radio before you put it back, in case you need to change the plugs
Offline Stevenebm
« Reply #6 on: December 22, 2011, 02:55:30 pm »
Will do mate.that's it ordered so will need to wait till it arrives then il give it a bash.
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #7 on: December 22, 2011, 03:21:56 pm »
Depending what year your car is, an therefore the aerial connectors you can do what I did which was to just remove the white and biege aerial caps (they just unclip) and push the now bare plugs onto the back of the stereo. I have a link howling what I mean, will try dig it up for you- saves buying and adaptor and works perfectly
Edit
couldn't find the link, but found this picture - which although from the US shows the connectors. I had these, just took the plastic covers off so i can plug both the connectors in the back (as too tight with the plastic on which im sure you know), therefore not needing the adaptor  :happy2:
« Last Edit: December 22, 2011, 03:38:10 pm by brookesb32 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: December 22, 2011, 03:23:53 pm »
if you don't have a roof antenna, then you need the correct adaptor or you will get an Open circuit fault
Offline Stevenebm
« Reply #9 on: December 22, 2011, 06:10:40 pm »
There is no roof antenna.I don't mind Waiting till it arrives as I need to pick up some torx drivers etc anyway.
