Author Topic: help with fault codes and cruise control  (Read 5072 times)
Offline jackarooney
« on: December 26, 2011, 09:44:03 pm »
hey all
i attempted to fit crusie control to my 04 gt tdi today i got as far as installing the new stalk i tried to install the wire from the steering wheel control module but it didnt seem to fit and i ran out of daylight and had to get home so i put the car back together to get me home.
my airbag light is stuck on ive tried to clear it using vcds but just comes straight back on :(
my skid light come on and brake judder
and i have about a million fault codes when i scan it lol one being steering wheel control module not coded 01042
and also my heating doesnt work the yellow lights come on show show the speed but nothing comes out and theres no noise...
everything was fine before i attemped to fit the cruise control
i will carrying on with it in the morning
what have i done :(
Offline four!
Re: help with fault codes and cruise control
« Reply #1 on: December 27, 2011, 02:05:56 pm »
Hi,
You're probably sorted by now but if not.......
The ESP light is probably because you have had the steering module disconnected. There is a procedure to reset this using vcds. pretty sure it involves several cycles of the steering left and right then a drive above a certain speed. The brakes and abs are connected to this system so hopefully that will sort itself when you do the adaption thing.
Check the airbag connector you must have had this off when you took the steering wheel off. Or under seat plug in case you slid the seat further back than normal when working on the s wheel.
Not sure on heater thing. fuse gone perhaps? especially if battery was still connected?
When you code the steering module there is also the choice of cruise on the wheel. make sure you have chosen cruise on stalk.
Any of those are worth a check
Good luck
Offline jackarooney
« Reply #2 on: December 27, 2011, 03:09:39 pm »
the heaters are working again now god knows what that was.
the airbag light is sorted :)
does anybody know the correct coding for crusie control or how to enable it?
if the car is stationary and i flick the switch to on should the light come on the dash?
thanks
Offline jackarooney
« Reply #3 on: December 27, 2011, 03:37:43 pm »
vcds reading
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 ET    HW: 028 101 184 3
   Component: R4 2,0L EDC G000SG  5803
   Revision: 12345678    Serial number: VWZ7Z0D9199878
   Coding: 0000072
   Shop #: WSC 00046 000 00000
   VCID: 79FDE9D74949
1 Fault Found:
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
            P1699 - 000 -  -  - Intermittent
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.86 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 1.0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0023170
   Shop #: WSC 00046 412 08192
   VCID: 3A7F36DB0CCF
1 Fault Found:
01486 - System Function Test Activated
            000 -  -
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 K
   Component: ClimatronicPQ35 061 0201
   Shop #: WSC 00000 000 00000
   VCID: 2F69178FC78D
No fault code found.
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 L    HW: 1K0 937 049 L*
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000527672
   Coding: E5890F0600041800001400001400000000
   VCID: 387B2CD332C3
   Part No: 1K2 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Part No: 1K0 955 559 K
   Component: RegenLichtSens 002  0505
   Coding: 00217125
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
   Component: 0M AIRBAG VW8   022 0500
   Revision: 04022000    Serial number: 0033FD08JFKA
   Coding: 0012365
   Shop #: WSC 00046 412 00000
   VCID: 2A5F069BFC6F
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000042
   Shop #: WSC 00046 412 31129
   VCID: 306B14F3DAB3
1 Fault Found:
01044 - Control Module Incorrectly Coded
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 960 L
   Component: KOMBIINSTRUMENT VDD 3354
   Coding: 0001401
   Shop #: WSC 00704 067 57207
   VCID: 326F1EFBD4BF
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 21001042070043
   Coding: 3D0F0B40070001
   VCID: 2759FFAFEF7D
1 Fault Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 8
                    Reset counter: 27
                    Mileage: 197242 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:02:25
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3354
   VCID: 326F1EFBD4BF
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0113
   Coding: 0000052
   VCID: 306B14F3DAB3
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 E
   Component: EPS_ZFLS Kl.0       1202
   VCID: 2E570A8BC087
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 S
   Component: 0W KSG              0560
   Coding: 82FC12087F2D8505C85AC61000
   VCID: 408B44336A13
   Component:   Sounder No Answer
   Part No: 1K0 907 719
   Component: Neigungssensor  002 0002
   Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
1 Fault Found:
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 316D11F7D1B9
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Component: PTC-Element         0404
   Revision: 00700000    Serial number:
   VCID: 2C530083F69B
End   ---------------------------------------------------------------------
Offline RSam84
« Reply #4 on: December 27, 2011, 05:04:06 pm »
Im not sure if this will help but i believe you will need to code engine part as well inside vcds to make it actually work its 11463 for a diesel! I fitted cruise control to my brothers golf and we set it up inside the steering control module as well but disnt work, i need to try that engine code but the car died yesterday!!
Offline jackarooney
« Reply #5 on: December 27, 2011, 06:24:19 pm »
Thanks will give it a go.
Offline Mattmatt
  • Newbie
« Reply #6 on: April 05, 2025, 06:33:22 am »
Hello, i managed to put CCS to my MK5 2005. All good until coding to ECU. Im getting error 22 and i have no idea why.
I have a shortcode but after put 11463 code to activate ill get error
VCDS: Login Invalid
Login Code Not Accepted by Controller!
You will have to turn the ignition Off for a while before trying again
Error 22: Conditions not correct or request sequence error.
Anyone any ideas? Thanks
Offline ZoliWorks
« Reply #7 on: April 05, 2025, 01:27:15 pm »
Depends on the year of the dash. My 06 jetta had the light on when I switched the cruise control to the on position while my 09 jetta only has the light come on when cruise control is actually engaged.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
